Today, I mowed the lawn. It didn't really need it, I just did it to knock off the high spots. So I ride around the yard and when I finished, I went to raise the deck for a quick scrape out and discovered I had failed to lower the deck to the normal cutting height and "mowed" the lawn at 4 1/2" instead of 3 1/2". Too embarrassed to go back out and remow, I just put the mower away, plugged it into the charger, and went inside.
I Really Blew It This Time
THe thing is, in a week, you will cut it at the right height.
And after you do that, there will be no evidence that you did it wrong last week.
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions😀 1Comment
We’ve all had moments where we “blew it” on a project, but that’s part of learning. I had a road trip once where I completely miscalculated mileage, and gasbuddy https://gasbuddy.pissedconsumer.com/customer-service.html ended up saving me by showing the nearest affordable station. In woodworking, it’s the same idea—you need tools that keep you on track and resources to help fix mistakes. The important part is not letting setbacks discourage youLast edited by pearson; 08-20-2025, 05:27 PM.Comment
Footer Ad
LCHIEN
