what model is this?
  • durango dude
    • Mar 2011
    • 937
    what model is this?
    Any of you old-timers recognize this saw model?
    http://westslope.craigslist.org/tls/4270429189.html
    Trying to figure out if it runs 110, and whether it has a universal motor or an induction motor.
    • 22085
    I don't know those old saws by name or number. But I do know of the technology used.
    I'm going to venture to say that all the old table saws like that used induction motors.
    Only the compact inexpensive benchtop direct drive saws that became available in the 90s had universal motors as a cost and weight and space savings measure. Then the BT3x was a pretty much unique exception as a belt driven saw with a universal motor... it has some identity crises as to whether its a table saw or a benchtop table saw or maybe just a precision woodcutting system. Anyway the universal motor puts it (the BT3) out of the heavy duty realm where you can cut continuously all day with it.
    I'm also going to guess that if its 1.75 HP like he claims it is dual-winding induction motor so it can run off 110 (15A) or 220 (7.5A) depending upon how its hooked up.
    If it was a 3 HP then probably it would be 220 only (or maybe 220/440V) and then it might be three-phase if intended for an industrial operation initially or one-phase for a smaller shop.
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      Loring summed up my thoughts exactly. Except for the 440. I wasn't thinking that big.
        Just a quick bit of checking over at owwm, shows me that, that, is either a King Seeley model or a later Emerson Electric (acquired parts of King Seeley from what I have read) with the heavy duty upgrade.
        Emerson Electric (last year according to this was 1966 for this model):
        http://vintagemachinery.org/photoind...il.aspx?id=146
        Early King Seeley model:
        http://vintagemachinery.org/photoind...l.aspx?id=6509
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          There's a member on the woodnet forum who restored one of those saws, adding a t square fence in the process. As I recalled, it turned out quite well and he liked it a great deal. Probably a 1.5 hp motor. The fence will need replacing with either a t2 or a vega40, which will result in a nice, very functional, saw.
          • All Thumbs
            • Oct 2009
            • 322
            • Penn Hills, PA
            • BT3K/Saw-Stop
            I have a friend with one (I think it is the same one). It looks like a cabinet saw, but the motor still hangs out the back on his like a contractor's saw.
            • durango dude
              • Mar 2011
              • 937
              Owner says "110 volts --- but 30 amps" ----- holy smokes!
                • 22085
                that's totally inconsistent with his claim of a 1.75 HP motor.
                30A@110V would be like a 3 HP or 3.5HP saw.
                Get him to take a picture of the nameplate and nameplate on the motor! Probably the saw was made to take a motor of either power rating and therefore the key is whats on the motor. my only thought is that maybe is the Locked Rotor Amps (LRA)? That's not the continuous fullload running current. If its LRA the nameplate would say that.
                Locked rotor current is usually twice the rated current. Sears for a while was infamous for using locked rotor current o rate the power of its machines, it made the developed power as they called it, twice the usual continuous power. Developed power is with the rotor locked. A machine using that much power would not do any useful work (zero movemment of the rotor), and would burn up in very short order.
                Aslo you probably want to see the motor, whether it hangs out the back like a contractor saw or its totally enclosed in the stand/cabinet like a cabinet saw.
                • durango dude
                  • Mar 2011
                  • 937
                  well ---- I'm now an honorary BT3 member.......
                  (if you guys will have me)
                    • 3790
                    Induction or universal motor, the point is that this saw has more going for it at 40+ years old that about any under $1000 saw on the market does today. If you were to strip this saw down on the floor the guts would be indistinguishable between a Powermatic 2000 or a Delta Unisaw. A wider table, a modern rip fence and good blade guard and you are in business.
                    capncarl
                      • 9562
                      Keep in mind, BT3Central is migrating albeit long term at this point, to Sawdustzone... You are always welcome!
                      Nice older saw...
                      Just FWIW, I would suggest you keep your BT around and restore that older Craftsman. That is a nice piece of equipment that deserves a fresh coat of paint, and a polished top etc...
