I hope this isn't an omen
  • Hoakie
    • Feb 2007
    • 382
    • Iowa
    Woke up this morning with a whole day of shop time in front of me. I was milling some logs into boards on the band saw and POOF! I blew the motor capacitor. I hope that is all I ruined. I do want a new bandsaw with larger resaw capacity and bigger motor, however I am pretty sure I can't afford that right now. Wish me luck with a the new capcitor on Monday
    John
  • Hoover
    • 1273
    • USA.
    Ok what Bandsaw do you have?
    No good deed goes unpunished
    • master53yoda
      • Oct 2008
      • 456
      • Spokane Washington
      if the capacitor is round and plastic it is a start capacitor and the most likely thing that will blow one is a failed closed start switch. if it is a metal can capacitor it is a run cap and they can fail over time. replaceing a start cap without resolving the start switch problem will blow the next one in about 10 seconds.
      good luck
      Art
      • Hoakie
        • Feb 2007
        • 382
        • Iowa
        this is the bs
        http://www.amazon.com/708901-JWBS-12.../dp/B00002265N
        John
        • Hoakie
          • Feb 2007
          • 382
          • Iowa
          I picked up new capacitor today and the motor started. I haven't cut anything yet to put a load on the motor, but I'm hopeful the $6 part saves me hundreds
          John
            • 9542
            A 1/2 HP 12" band saw? Whodathunkit....
              • 22039
              did it blow while running or while starting the motor?
              A starter cap should be disengaged when running so if it blew while running then probably the starter centrifugal switch may be at fault as much as the capacitor and may repeat itself shortly.
              how did you know it blew - big pop and bad smell? like one of my fellow engineers said, like a little old lady pissed in your machine?
                ...like one of my fellow engineers said, like a little old lady pissed in your machine?
                Now there's a visual that I just don't wanna get my head around...
