quickee name
  • mhoy
    • 36
    • Sunnyvale, CA, USA.
    quickee name
    Nifty s/w for a forum. Seems to be used by a number of places.
    Anyway guess things work.
    Mark
    • 22106
    quickee name
    Here's a quickie project finished in about 5 hours for a baby
    party. Obviously his name is Harrison. The name is long so I
    used smaller letters than usual making the detail a bit
    tighter than normal.
    Step 1 - Compose in Microsoft word, 128 point type, and print it. I draw a solid bar underneath to tie it all together.
    Step 2 - Glue it to the wood
    Step 3 - Mark all the inside tight corners with a circle template,
    label the size holes like the "S" here.
    Step 4 - drill the holes on the DP using brad point bits
    Step 5 - cut out the letters on the scroll saw, cut out the inside cuts, too.
    Step 6 - Peel off the template, belt sand off the rest. clean
    up the edges as best you can using 1" belt sander and needle files.
    Step 7 - finish with a coat or two of tung oil then a clear
    spray varnish several coats with a bit of sanding
    • Rodent
      • 111
      • Yorba Linda, CA, USA.
      Cool project. We have twins on the way, due in December. I'm definitely gonna have to do this one. Besides, it's the best shot I have at getting the wife to approve buying a scroll saw with diaper money (it's all diaper money now).
      Dave
      • tfischer
        • 2349
        Heh, Harrison is my wife's maiden name -- wanna make one for my FIL?
        I don't think I"d have the patience (or talent) for scroll saw work, but maybe someday I'll give it a try...
        -Tim
        • jethro
          • 1081
          • Newark, DE, USA.
          Nice, Loring. What font is that? It really seems to lend itself to this type of scroll work.
          jethro.
          <font size=\"1\">Never attempt to teach a pig to sing; it wastes your time and annoys the pig. -- <i>Heinlein</i>
          http://www.jeffriegner.com</font id=\"size1\">
            • 22106
            Old Century. came with Print Shop
            I like the Swashbuckling "O" and the swagger in the tops and bottoms of the letters (not flat top) like the A, H and R if you look closely.
            let me know if you can't find it.
            • tribalwind
              • 847
              • long island, ny.
              Nice job
              i also like cutting out thick plaques and designs on the scrollsaw
              ive found using certain bits with a dremel works good for cleaning up the insides.(i usually have alot of cleaning in there as i tend to only use spiral saw blades)
              long diamond bits and the sanding wheel are especially handy.sometimes nothin but an emery board will fit though.
              cool font btw
              heres 1 i did with a sort of customized 'font' but i cut out the letter rather than the space around it,inverse i guess.
              • monte
                ***** Windbag
                • 5242
                • Paw Paw, MI, USA.
                • GI 50-185M
                Nice work Loring!
                Monte (another darksider)
                • Tundra_Man
                  • 1589
                  • Sioux Falls, SD, USA.
                  Excellent!
                  Terry
                    That's a very thoughtful gift for new baby. Might get him interested in wood working from the very beginning.
                    • billwmeyer
                      • 1868
                      • Weir, Ks, USA.
                      Loring,
                      Thank you so much for this post. My Father in law made my daughter one of those before he died, and A letter broke off of it and got lost somehow when she moved. I have been wondering how to repair this for her. Now I can.
                      Thank you.
                        • 22106
                        Popped out a couple more this week
                        • BobSch
                          • 4385
                          Looking pretty good there. Guess I'm going to have to invest in a scroll saw one of these days.
                          Bob
                          • lcm1947
                            • 1490
                            • Austin, Texas
                            • BT 3100-1
                            I sure wish I'd had found this hobby sooner. You guys are great.
                            Man, one of these days - I hope!
                              • 22106
                              They're not very expensive and the supplies (scroll saw blades) are real cheap. Not like a lathe that keeps on requiring new chucks, toolrests and chisels.[8)]
