Lathe Speed
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    Lathe Speed
    None of my books touch on this subject, and I'm newish to turning. What is a suggested maximum rpm for a 12" diameter workpiece?
    Jim Frye
    The Nut in the Cellar.
    • 3126
    I can't answer your question directly, but my Shopsmith speed chart shows a max speed of 850 rpm for anything over 6". They conveniently stick the chart directly to the headstock above the speed control. I think the slow range should be slower for larger items, but 700 RPM is as low as it goes without a speed changer or upgrading to the DVR motor for $2500
    • Jim Frye
      Jim Frye commented
      Thanks. My lathe has electronic speed control ranging from 500 to 2500 rpm. I'm hoping 500 rpm will be slow enough for a glued up blank.
    • 22106
    RPM max = 9000/Dia in inches. (rule of thumb)
    Tangential speed = RPM x Pi x Dia (Physics)
    Tangential speed (inches per minute) (max) = 9000 x Pi "
    Tangential speed max (inches per second) = 150 x Pi ~= 500 inches per second.
    • Jim Frye
      Jim Frye commented
      Thanks. The calculation seems to be fairly common now that I took time to Google the quetion. Nice to have confirmation.
    I got this from someone on this forum several years ago.
    Click image for larger version  Name:	Bowl lathe speed.jpg Views:	0 Size:	230.6 KB ID:	86032750
    I needed it because we had a few new pen turners who had been long time bowl turners and they kept insisting that we never needed to turn more than 700-750 rpm. it was hard convincing some of them that 2500 rpm on a 3/4" diameter was slower cutting speed than 700 rpm on a 12- 14 inch bowl.
