MLCS Technical Manual 14th Ed 2011 Router bits
    One of the things I miss now that MLCS Woodworking site has been taken over by apparently another party is the technical manual MLCS used to publish on how to use their bits. Which is applicable to most other bit makers similar function bits. I found it to be an excellent technical resource.
    The last one I downloaded and kept appears to be this one, 14th Ed 2011. The download date seems to be 2020 so I don't know if they made any later than that. If you open PDFs like this they will often be saved in your "DOWNLOADS" folder; I found these there. I use a couple other computers often, I'll look at those.
    I am putting the PDF here as an attachment.
    Does anyone have a more recent one to share?
    • 3126
    Great resource. I've always just downloaded the instruction sheet for each bit as I purchased it.
