Flexzilla Air Hose
    Flexzilla Air Hose
    Has anyone heard anything about the Flexzilla Air Hose, or used one? Lee Valley obtained some and has them on special right now (limited quantities)
    http://www.leevalley.com/US/wood/pag...,43465&p=69369
    I picked up a Kobalt 100' PU hose last year. I like it, but it can be a bit unruly at times.
    I have a Hitachi 50' PU hose that I got on Loring's recommendation. There are a lot of things I like about it, and a few things I hate. It's nice and light, very flexible, and puts up with my abuse very well, but it tangles very easily. I think a hose reel would fix my problems with it, but I don't want to bother, at least not yet... The irritation is only mild, and infrequent... Just gives me something to complain about instead of having real problems...
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      I have one of those Flexzilla hoses. They're nice but they also are not quite what I expected it would be. They claim to not have coil memory but mine does as I still need to keep twisting the end of the hose when I uncoil it. The thing I like the most about it though is that it's very light weight. You hardly realize you're dragging a hose around behind you.
      • jseklund
        • Aug 2006
        • 428
        I have one, and I think it is completely awesome. It's so much more flexible than the PVC stuff, it seems to have held up very well over the past 4 years or so, and it has a little memory but not much. Buy it, you'll be happy.
          It looks very interesting and hearing a comment that it's light might make me want to try it. I've been using rubber hoses, and the coil type. I tried one of the blue PU hoses because it was very light, and I like that about it. It's not just dragging the hose, but when attached to an air tool, a light hose can make use on a daily basis less strenuous.
            I bought one of those $6 orange electrical extension cord reels that has a black hand grip in the middle and a crank on the outside of the spool, that they sell at the box hardware stores. Easily holds 50' PU hose and much more. I wind my PU hose on it. When I need it I unwind it onto the drive way usually about 25 ft down and then back. When I'm done I lay it back on the ground in a straight line with maybe one bend or turn in it. Wind it up. THis way it has no twists in it - the hose lays out with no twists and has very little memory. The main reason for laying it out in a line is to get enough tension to roll up OK. When I say wind it up or spool it out I walk away from it or walk towards it as I reel it out or in, so as not to drag it.
            http://www.lowes.com/pd_71677-1373-K...&storeId=10151
              Great, all I needed was another Lee Valley order... Can't just put a lonely hose in a box and ship it. It'll need some other tools in there to keep it company.
              • sweensdv
                • 2873
                • WI
                You might want to check locally for one. I don't recall if mine was on sale or not at the time I bought it but I paid less for mine than what Lee Valley is selling them for.
                  I'm assuming from the physical description that the flexzilla is a polyurethane hose. Unlike most of the ones i've seen for sale this one is a 3/8" ID, the ones i bought were 1/4" ID. Larger is of course better for airflow.
                  The problem is that it has no memory but it doesn't like to have axial twist. When you take a straight hose and twist the end it will cause a coil loop to occur rather than just spreading the rotation over the length.
                  • RAV2
                    • Aug 2007
                    • 233
                    • Massachusetts
                    • 21829
                    I've got all kinds of hoses around the house.
                    This 100' one from Harbor Freight can be picked up for about $15 with a coupon. It is not bad but it is certainly isn't as flexible as a rubber band.
                    http://www.harborfreight.com/100-ft-...ers-93338.html
