what to do with ..
  • toolguy1000
    • Mar 2009
    • 1142
    • westchester cnty, ny
    what to do with ..
    a damaged TS blade? i dropped my 10" c-man 40T combination blade today by accident. here is the pic; notice the two center teeth missing their carbide:
    short of having it repaired (my cost was $10-12), any ideas on what to do with it? i could just keep it as my "just in case there's any metal in this material" blade. any other constructive ideas?
    • 22109
    well, the first question is does it still cut in an acceptable manner... i.e. does it vibrate because its out of balance, and if not, try cutting, does it still cut reasonably smoothly for use as a junk wood blade? If the rest of the teeth are dull its probably a pice of trash but if the rest of the teeth are sharp it may still cut OK.
    Fixing teeth on a $10 blade (when new) doesn't seem to make much sense as it'll probably be $5 per tooth to repair. if it doesn't spin or cut well, then make a clock face out of it or pitch it.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      If it still cuts, great, but it'd be wise to have the other teeth checked for cracking.
      IIRC, that's the Craftsman Pro 32808 that was reviewed by Wood a while back, is made by Freud, and is the equivalent of the former Freud Avanti TK306 40T blade. It's approximately a $30 blade (a good example of one at that) ... I wouldn't let the fact that it only cost you $10-$12 (a great price!) stop you from have it fixed and sharpened, but if the repair costs get to be much over $20, it'd probably make more sense to just buy a new Freud Diablo for ~ $30.
        I agree with the comments so far. It might be worth keeping if it still cuts and you occasionally cut up junk wood or pallets. Whether any other tips are affected, that may fling off while cutting is another consideration, or that the blade is worth putting the money into to fix.
        • herb fellows
          • New York City
          Even though you see 2 carbide tips missing, this doesn't mean that's the extent of the damage. It could be slightly bent, there could be other teeth about to fly off, and you certainly don't want that happening on your watch.
          For a few bucks, you can get a battery operated clock motor and turn it into a clock. Have a little fun painting the clock face, or if you have kids, tape up or otherwise protect them from the teeth and let them decorate it.
          I'm sure they would love to have a hand in something that would be in dad's shop.
          • Daryl
            • 831
            When your brother in law wants to borrow your miter saw, that is the blade you put on it for him.
              You could always cut it up for cabinet scrapers, marking knives, etc.
                I have taken old TS blades that are uncoated, and cut them up to use as bracing on the underside of a pickup truck tool box for installation of large radio antennas (CB / HAM radio stuff) but that typically requires 1/2" hole, so circ saw blades are better for that task...
                • toolguy1000
                  • Mar 2009
                  • 1142
                  thanks for the comments. if there is a wining suggestion, i think this is it .
                  • Daryl
                    • 831
                    Actually, I like my brother in laws, they are a great bunch and would go the distance for me and I for them.
