follow up to the drum sander question
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    Okay, I'm pretty decided on the Grizzly 10-20 for the drum sander, and I know these things need very good DC. My 2hp HF unit won't power on any longer (starts to spin up and blows the fuse, I think it's the starter capacitor). So do I fix the HF unit, or get another unit entirely? I have a budget of about $200-250 for this. since that's what I'm saving on the sander. I did some looking at just a new blower (thinking I might be able to get a bigger assembly and attach it to the HF filter set up) but the better ones are $300+ from what I see.
    Lakota's Dad
    • 9560
    Couple of quick questions...
    #1. Do you have a separator for the dust collector? If not you will need one...
    #2. Do you have a Wynn cartridge on that HF DC? If so you are WAY ahead of the game...
    You CAN try to fix the existing HF motor. I doubt it is the start cap though, that if I recall right simply won't get the impeller moving, Or is it humming and blowing the breaker? Then I would look at the start cap...
    You might want to take the covers to the motor off and simply blow it out. Could be sawdust build up. (yes they get dusty...)
    Of course you could pick up another HF DC with the coupon for $139.00
    If I were to replace my DC today, and had the budget you do, AND had the setup I already do with the Thien AND the Wynn, I would be very tempted to pick up a Delta 50-760. Yes it is a 1.5 HP DC, but it flows with the best of the 2HP units... I'd simply move the Wynn over, and make sure the Thien fit under the stand. (Okay I would probably build a new one out of a 30 gallon steel drum or trash can)... Side inlet thank you very much, no need to introduce extra bends in the system...
    • Russianwolf
      • 3152
      I do have a separator in line already. Haven't gone for the filter yet (always meant to and this will likely get me going on that too).
      The impellor on the HF starts spinning, but blows the fuse before it can get to full speed. tried it on several circuits and the same result, so it's not the circuits or the breakers. The one it lives on normally only has it and the sump pump which is never on when I'm in the shop.
      Lakota's Dad
        • 22084
        if it starts spinning then its probably not the start capacitor altho i suppose a wild scenario can be made where its responsible. (maybe where the centrifugal switch is incorrectly wired or malfunctioning so it shorts the winding to ground instead of removeing-opening up the the start capacitor shunt, or maybe the capacitor has an internal intermittent short that shorts out when the motor starts vibrating).
        Highest current is usually drawn at the point of power being applied BUT maybe you have a bad breaker that trips after a delay because usually breakers are designed to pass an initial high current. I would suggest swapping if possible breakers within your breaker box to try another breaker of the same amperage. I can't really think of a likely scenario where that's a DC motor fault. The running current of a HF 2 HP DC is very close to 15AMps so if a breaker is a little weak it may well tripafter a second or two.
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          +1 on replacing it with another HF. the repair of the existing unit would probably cost more than it's worth.
          • Russianwolf
            • 3152
            Well.... whet down and removed the extension cord and pulled it directly to the outlet to make sure it was getting all the power. plugged in and it stayed on longer, but "pop". I then went up to confirm with breaker it was and its only a 15AMP. I then found out that despite the labeling in the box, our Computer room outlets are on the same circuit as the sump also.
            So I'll try swapping to a 20AMP breaker and see what that does.
            Lakota's Dad
            • smorris
              • Apr 2003
              • 695
              • Tampa, Florida, USA.
              Forgive me if I misunderstand but...I don't think it would be a good idea to swap the 15 amp breaker for a 20 unless the wiring is rated for 20. That could end rather badly.
              • Russianwolf
                • 3152
                All the visible wiring in the basement is 12/2, and I have a feeling they used it for all the 110 circuits (why complicate things with different wiring types).
                The DC is rated at 20AMPS peak so no clue on how I was running it on a 15AMP circuit for so long.
                Lakota's Dad
                  If the wiring is 12ga then you should be ok with the bigger breaker. What size is your extension cord? If you have to use an extension make sure it is 12ga or better.
