Weird "Ripples" in Bandsaw Cut
  • woodturner
    • Jun 2008
    • 2047
    • Western Pennsylvania
    Originally posted by buckeye95
    Additionally, when I look at the finished cut, I see a defined ripple in it.
    The ripples are indicative of a blade weld problem.
    A lot of these blades are not perfectly aligned at the back edge, so they "click" and wander slightly when the blade passes through the wood, causing a ripple.
    Look at the weld and see if it is flat on both sides and the back.
    The fix is simple - CAREFULLY hold an arkansas stone against the back edge of the blade as it is running - that will smooth the edge.
    • d_meister
      • Feb 2009
      • 187
      • La Conner, WA.
      My guess is too many TPI. I bought a brand new blade (Ridgid) at 12 TPI and tried to push a 5" high piece of soft mahogony through it and just about pushed my 150lb saw over. I bought a 3TPI blade and everything works great.
      • buckeye95
        • 267
        • Columbus, Ohio.
        • Ridgid TS2400
        Thanks everyone for your comments.
        I will check on these items in the next few days if i can get away from shovelling (Central Ohio can be lots of fun in the winter!!).
        Thanks again,
        Pete
