Just got back from a visit to a new (to me anyway) HF store in Syracuse. Like a vast candy store or really more like a hugh Big Lots store. Anyway to the ?. I was looking at a crown staple air gun that had a crazy price of less than $20 with coupon. I am usually pretty hesitant in buying complicated power/air tools that are made in China. Where do you go when it goes belly-up after 6 or so months? Or being that cheap do you just s**t can it and get another? Has anyone out there had any experience with HF's air tools? Thanks for what ever advise you can come up with.
HF Nailers
Tags: None
I have had the 18 guage brad nailer and the 18 guage brad/stapler combo for a few years. I have never used any other nailers, so take it for what it's worth, but I love both of them. I have gotten tons of use out of both. I paid less than $20 for each, probably less than $10 for the nailer.
One word of caution, DO NOT use the HF brads. Those are junk and will jam. I use Bostich from Lowes, and I rarely have a misfire or jam.
You can't go wrong with HF's return policy.Joe -
I have and use:
18 ga brad nailer (46309)
16 ga finish nailer (current item number is 66872)
23 ga pin nailer (current 97526)
20 ga 1/2" crown stapler (current 97572)
18 ga 1/4" crown stapler (current 97521)
The ones I have were purchased several years ago, and except for the 18 ga brad nailer, are different item numbers from what currently is listed. They generally look the same, with a few cosmetic differences.
I have been pleased with them, and would purchase each again if I had to. I've used HF branded fasteners, without the jamming issues mentioned by JoeyGee. I've also used Porter Cable fasteners without issue.
I have no complaints about any of them. Okay, maybe there's just one. The 1/4" crown stapler has the HF cosmoline stench that won't go away.Last edited by Brian G; 12-04-2009, 07:09 PM.BrianComment
I have the HF finish nailer mentioned above. I abuse the snot out of it, using HF fasteners, and it keeps on chugging along...
I am heading over to HF to pick up the 21 degree framing nailer, and a couple of boxes of nails this weekend. I have a fencing project I am working that I don't want to manually nail up...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
I have the 18 ga combo and have used it a lot, most recently with 1" staples on carpet. I'm with Joe in that I use the Bostich fasteners only. Never tried the ones from HF.
My only complaint was the safety mechanism. It is a 'was' because I removed it. I could not get it to fire a nail on much of an angle.Why doesn't the word 'planing' show up in my computer spell check?Comment
I have the 6 in 1 framing nailer and I love it. I've shot about 3000 nails through it, without the first jam. I've shot the HF nails, Grip tite, and paslode with out problems. A word of caution on the HF nails. You mentioned that you were doing a fence, which would require galvanized nails. The HF galvanized nails are only electroplated, and not hot dipped. They rust pretty quickly. Spend the few extra bucks and get the hot dipped.I have the HF finish nailer mentioned above. I abuse the snot out of it, using HF fasteners, and it keeps on chugging along...
I am heading over to HF to pick up the 21 degree framing nailer, and a couple of boxes of nails this weekend. I have a fencing project I am working that I don't want to manually nail up...Comment
I have the 18 ga. brad nailer, 16 ga brad nailer, 15 ga finish nailer, and a couple of the stapler combos. The 18ga and 15 ga are by far the best of the group. I have used both extensively with no problems. I would and have recommended them without hesitation. The 16 ga is really nose heavy and the combos work but there aren't great.I think therefore I .....awwww where is that remote.Comment
I have the 23ga pin nailer, works every time. I even use the HF pins without problem. Kind of hinting about an 18ga brad nailer or a narrow crown stapler.Sometimes the old man passed out and left the am radio on so I got to hear the oldie songs and current event kind of thingsComment
I had one of their framing nailers. I don't remember the number, but it was an almost exact knowckoff of a Bostitch N80. I used it to finish two basements, build two decks, and a whole bunch of other stuff. I don't have it anymore because I "loaned" it to a coworker and he liked it so much that he kept it for over a year (fortunately, he felt guilty and bought it from me after that).
My dad has a bunch of HF nailers, so I've also used an 18 ga brad nailer and a roofing nailer. The brad nailer seemed to work fine, but I wasn't a fan of the roofing nailer. It jammed fairly regularly.Comment
I have the 1/4" crown stapler/brad nailer gun that was less than $20.00. I have no complaints except for the color (purple) and it works great.
I haven't tried brads in it since I have a P/C brad nailer but, this way, everything stays locked and loaded.Do like you always do,,,,,,Get what you always get!!Comment
I have several HF air nailers, every now and then I pull the trigger and nothing comes out, pull it again and it nails. Don't know why and it doesn't bother me. One thing though, the combo stapler/brad nailer uses the same hammer for both thus the brad has a big rectangle hole the size of the staple for a countersink. That does bother me so it rarely gets brads in it and I use another for brads. If I am doing trim work I keep long brads in one and short in another. That keeps me from forgetting what is in the gun and screwing something up with either a long brad that splits the casing out or a short one that fails to penetrate the sheetrock.
BillComment
Ditto on the brad nailer. Had mine for a couple of years and never had a misfire. Have even used some of the brads that came with it.Don, aka Pappy,
PlatoComment
that's why i don't own a combo stapler/nailer.
Who makes a decent hot dipped galvanized nail for these guns?I have the 6 in 1 framing nailer and I love it. I've shot about 3000 nails through it, without the first jam. I've shot the HF nails, Grip tite, and paslode with out problems. A word of caution on the HF nails. You mentioned that you were doing a fence, which would require galvanized nails. The HF galvanized nails are only electroplated, and not hot dipped. They rust pretty quickly. Spend the few extra bucks and get the hot dipped.
Yes I would MUCH rather shoot hot dipped nails...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
LCHIEN
