I just assembled my drill press (Delta DP400). The table moves to the left and right so easily that it makes repetative drilling impossible. I have tightened everything I can find. Am I missing something?
Drill Press help needed
\"Experience is the toughest teacher. You get the test first and the lesson later.\"Tags: None -
there should be a screw lock that tightens the split collar of the table support to the column.
The screw enters one side (unthreaded, thru-clearance hole) and screws to the threaded side on the other side of the split. It pulls the split together and locks the table in place.
Sometimes, people assemble it backwards inserting the screw into the threaded side first and then when they tighten it it does not pull the split together to lock the table to the column. I have heard of this error more than once and they always think because the screw is tight it should not move.
I'll bet that's what you did.Last edited by LCHIEN; 10-17-2009, 11:37 AM.
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
Thanks. That is the exact error I made. This really is the best site!!!\"Experience is the toughest teacher. You get the test first and the lesson later.\"Comment
That's a pretty common layout. Not sure if I have seen it done differently...Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog.Comment
LCHIEN
