Are Circular Saw Blades Worth Saving?
    The floor on my new shop is 1/2" OSB over 3/4". Between the tarpaper, nails and leveling compound in some spots I am chewing up circular saw blades on the floor prep. I suspect part of the problem may be the tar paper gumming things up. Is it worth trying to clean/sharpen these blades or just go get new ones?
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    David,
    Use "disposables" on OSB. Save some of the blades. The steel makes good scrapers.
    Steve
    • Hellrazor
      • 2091
      • Abyss, PA
      • Ridgid R4512
      The glue in OSB eats circ saw blades...
      • DUD
        • 3309
        • Jonesboro, Arkansas, USA.
        Use oven cleaner on them to clean and buy cheap blade for this kind of work and
        dispose of them. Bill
          Thanks fellas. I won't plan to to keep these blades then.
            • 22104
            Make clocks out of them... Sears used to.
            • rnelson0
              • Feb 2008
              • 424
              • Midlothian, VA (Richmond)
              • Firestorm FS2500TS
              As a follow-up, what do you guys do with dead blades that you do not plan to keep? Do your local recycling groups accept them or do they go in the trash?
              • bthere
                • 462
                • Alpharetta, GA
                I had a batch of miscellaneous cheap blades that weren't good for their intended use, but I have a hard time throwing stuff like that out. I happened to mention it to someone at some PTA function and they knew of a lady who paints on saw blades (both hand saws and round blades) and sells them at craftshows. I gave them a box of the blades and that was the last I heard. I don't know whether they ever got painted or not.
                Anyway, my shop ended up with a few less old chunks of metal cluttering it up.
                • nadz
                  • 82
                  • Rocket City, AL, USA.
                  scraper? scrapper?
                  Originally posted by scmhogg
                  David,
                  Steve
                  how does one make a scraper from an old saw blade?
                  Proudly piddling in my garage shop | BT3K, Rigid 10" CMS, Rigid 12" Planer, HF Jointer
                  • ironhat
                    • 2553
                    Ditto. Who woud you get to gut a square edged rectangle?
                    Blessings,
                    Chiz
                    • scmhogg
                      • 1839
                      I got the idea from "Make Your Own Woodworking Tools", by Mike Burton. Fox Chapel Pub.
                      He puts an abrasive blade in his table saw.
                      I was kind of queasy about such a blade in my precious BT3000. So, I used a 4" grinder, with some difficulty. I made the longest cut possible without hitting the arbor hole. I used my fixed belt sander to straighten the edge. I took the teeth off, but left the round edge.
                      I used the usual procedure to prepare and roll the edge.
                      I liked the feel of the round edge, when scraping a wide board. The additional thickness made it unnecessary to bend the scraper, and it didn't get as hot as usual. It held a hook really well.
                      I light of the "no pics, didn't happen" rule. My cop out it...I loaned it to a friend to finish a bench top. He "misplaced" it. Guess I'll have to make another.
                      Steve
