Question on miter saw brake
  • lago
    • 473
    • Lago Vista, TX.
    My brother has a 12" Craftsman miter saw, probably 7-9yrs old. It's making noise after he finishes the cut and thinks it is something with the brake.
    Is there actually a brake shoe or does it work via the switch to make the motor run backward to slow/stop.
    TIA
    Ken
    • 22108
    i think they have electrical blade brakes, not mechanical.
    Probably something like shorting out the field wiring when the saw switch is off.
    • jhart
      • 1715
      Every once in a while, I'll get a mall piece of cutoff wood down in mine and it make a heck of a noise. Usually just lift it up, turn it over and shake it a bunch and the piece comes out and it's good to go again.
      • Sam Conder
        Woodworker Once More
        • 2502
        • Midway, KY
        • Delta 36-725T2
        You pretty much just described 90% of the tech support work I now do on the PC's here at work.
        Sam Conder
        BT3Central's First Member
          Had a saw that made a noise like that, found the blade retention nut was not tight!
