Mini Max S45
  • needshave
    Mini Max S45
    Hello everyone,
    I have inherited a Mini Max S45 bandsaw. Relatively never used. I now have her in my wood shop, however I have no manual and no Band Saw Blade. Additionally, I can not find out what size blade is required. I believe it might be 143" but not sure. Also could anyone tell me what the max width for this machine might be as well?
    I have looked on the net and can not get an definitive answer to the size of the blade. Woodcraft and wood werks has no idea so I would appreciate any help that is offered. I have wore out a pair of shoes just wlaking around her.
    Thanks.
    Just a thought, run a string around the wheels through the path, and measure your distance on the string maybe?
    Give the good folks at Suffolk Machinery a call at (800) 234-7297 and ask them their advice. They are the bandsaw blade gurus...
    Last edited by dbhost; 11-12-2008, 04:33 PM. Reason: Had to get Suffolk Machinery phone number...
    • just started
      • Mar 2008
      • 642
      • suburban Philly
      Take a piece of string and put it around the wheels the way a blade would go, mark the overlap point and then measure the string with your tape measure - that's your blade length.
      Max width of what? Post pix and all info from every plate/sticker anywhere on the unit to hopefully give us someplace to start for other info.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        Minimax's service is legendary...I'd contact them.
        http://www.minimax-usa.com/index.php...id=1&Itemid=35
        • jonmulzer
          • Dec 2007
          • 946
          • Indianapolis, IN
          Pretty sure it is 143", but don't quote me on that. Run your string, take your measurement, see if that is close. This is another reason that I keep a really long seamstress type measuring tape in my bench. Whether I could find it if I needed it.....is another story. That machine should also take up to a 1" width blade, IIRC.
            strings too stretchy... I'd measure the wheel diameter, then the distance from wheel center to center (L).
            The blade length is then (pi x D) + (2 x L)
