Lee Valley Clamp Really Sucks
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    I finally got to use the double sided vacuum clamp system from Lee Valley. I got the double sided model so I would be able to use the clamp at different locations. It works on a venturi driven by compressed air. You need at least 2 cfm at 80 psi.
    http://www.leevalley.com/wood/page.a...43&cat=1,43838
    I connected it with an inexpensive valve and pressure regulator from HF. A couple of bucks vs the $22 accessory offered.
    I put the unit on my router table and a 12" by 12" piece of 3/4" plywood on top. I took a few second to charge up. Then I was able to pick the heavy router table up without the ply detaching.
    It has made some difficult planing on small box lids easy. I had difficulty with a bench hook and feared for my blade with dogs.
    I am really impressed by how well this little thing works.
    Steve
  • DUD
    • 3309
    • Jonesboro, Arkansas, USA.
    Steve
    That sounds good. Bill
      Steve,
      Good news. How about a review in the reviews section? This kind of info might be helpful down the road to folks, and that section would make the info easier to find...
