X-workhorse
    X-workhorse
    Anyone seen this? Interesting folding plastic and aluminum tool stand.
    http://toolmonger.com/2006/09/12/han...s-x-workhorse/
    So my Sister gave me one of these. Says Black and Decker on the package but the only web site reference i see is Home Depot with a Husky name on it. May actually be made by Keter Plastic Ltd.
    One foot is actually cleverly adjustable for leveling, The locking top comes off and snaps to the center post when folded for flat storage, about 3" thick. Got some 3/4" tapered holes in the top I haven't figured out what for. Because the bottom is not flat but a honeycombed web it'll be hard to use conventional clamps to attach work to this thing. Fairly light but holds 750 lbs. four rubber feet at the top four corners make for putting a larger top on this thing non-skidding. 30-3/4" tall.
    Interestingly I just found Tom HIntz wrote a review on this in Oct 2005. http://www.newwoodworker.com/reviews...rkhrservu.html
    Was a Husky item then, wonder where it's been hiding for 2 years?
  • gwyneth
    • 1134
    • Bayfield Co., WI
    That's pretty amazing. It took a lot of searching to discover that it costs only $35 (though I guess I could have checked the Home Depot web site).
    One write-up said the holes are for attaching tools such as a miter saw.
    Isn't Keter is the company that first introduced plastic sawhorses a decade or so ago?
    • gad5264
      • 1407
      • Columbus, Ohio, USA
      • BT3000/BT3100NIB
      I have two of these in my garage. I bought them at the BORG about 2 years ago. When I need a quick base to work on this is the first piece I reach for. I like them alot.
      Grant
      "GO Buckeyes"
      • softop41
        • 470
        • Plainfield, IL, USA.
        I have had one since they first showed up at the Borg. As gad5264 said, it is the first thing I reach for when I need a temporry stand for anything. I used it as a stand for my 13' planer for a while, then for my wet sharpener. It was pretty darn stable for how foldable and compact it is.
        Jerry
        Jerry
        • frumper64
          • 376
          • Garland, Tx, USA.
          Now available at Harbor Freight
          I've had one of these I got from HD for a year or so and really like it - quick to set up, very stable and sturdy. On a side note, I was at HF over the weekend and noticed that they had one on display there for something less than $30 - looked identical. Sorry, I didn't notice the item number, but can go back and check if someone needs it
          64sedan_at_gmail.com
          • AAJIII
            • 306
            • WANAQUE, NJ, USA.
            • Steel City 10" table saw
            stands
            I have a bunch of them in my shop, they are great for just about everything including a temporary tool stand for a planer, cms, etc.
            I don't even use my standard saw horses anymore.
            Al
            AL JEWELL
            • gwyneth
              • 1134
              • Bayfield Co., WI
              If Al and Gad have successfully used them as planer stands, that's pretty impressive.
              I tried to find the corporate site to see if there are add-on accessories but it's part of an Israeli plastics conglomerate.
              Maybe the 3/4 inch holes take the Workmate "dogs" (which Rockler sells a clone of, 4 for 3.95?)
              Clearly it saves a lot of money being hundreds of miles from a BORG--these sound terrific.
                Both the B&D workmate plastic dogs and standard workbench dogs use 3/4" holes. I thought of that but it would be hard to use the dogs to back up because for dogs you either need a bench that's going nowhere to back up the dogs (in this case the bench weighs 15 lbs so you can't effectively push against the dogs) OR you need a clamp/vise attached to the bench so that the vise tightens against the dog using the benchtop as the common base, but in this case there's no way to attach a vise.
                In my classic B&D workmate there's dog holes in both sides of the top and the vise-action of the top will both tighten on and hold items securely between dogs, and the weight of the bench if you put your foot on the step would hold items securely as you sawed or pushed sideways on it.
                Where the X-bench would seem to fail compared to the classic workmate is that there's no good way to hold the workpiece, its more of a stand only than a workbench/vise like the workmates.
                Maybe there's a jig to build that functions as a vise to clamp items between the various 3/4" holes (There's about a dozen in four lines)
                • ryan.s
                  • 785
                  • So Cal
                  There are similar ones from stanley that came with a vice and bench dogs.
                  http://www.stanleytools.com/default....+2+Vice+Clamps
                  I picked up a couple of these on sale for $20 IRRC at HD a couple of years ago. Pretty handy when you need a temporary bench.
                  • rja
                    • 422
                    • New Kensington, Pennsylvania, USA.
                    I wonder if this could be used for a quickie router table?
                    • Thom2
                      • 1786
                      • Stevens, PA, USA.
                      • Craftsman 22124
                      like these?
                      • goslin23
                        • Feb 2007
                        • 233
                        • Richmond, TX
                        • Rigid TS3650
                        When I 1st began my journey back into woodworking, this was my 1st purchase. I've used it for many things.. tool stand, work surface, step stool etc. It's built well and folds up and out of the way when not in use. I have been considering a 2nd one and now that you've reminded me about it, I think I'll go pick up another one this weekend.
                        -=gos=-
                        If it ain't one thing... It's 12 @#$%ing things!
                        • gwyneth
                          • 1134
                          • Bayfield Co., WI
                          The sloped design of the B and D dogs does provide some cam and wedge action independent of the vise-action of the top--i.e., several of them can be adjusted to wedge in a workpiece, as dog wedges did for thousands of years before screw vises were devised. However, the weight of the bench obviously makes this possible.
                            Not really, the center is supported both vertically with a post and cross members, no room for a router. At 750 lbs capacity, it would be overkill for a router, anyway.
                              Originally posted by Thom2
                              like these?
                              yeah, those are nice, too bad they each cost as much as the table.
