Bandsaw blade length?
  • scoly
    • Jun 2003
    • 395
    • Lubbock, Texas, USA.
    Installed new urethane tires (thinner that the old tires) and found that when I tension the blade the wheel rubs the surrounding housing. I'm guessing that the blades that came with the saw when I bought it used) were actually to long for the saw. If that is the case I need new blades in the proper length.
    How do I go about measuring for the blades? Feel like I could crank the tensioner to 0 and stretch a string around the wheels leaving a bit of slack, measure the string and get a dimension close to the standard blade length. Would this be the way or can someone give some guidance?
    Thanks
    Steve
    It\'s the combined experience of the members on this board that make it such a great place.
    What you could do is set the wheel in the middle of the adjustment allowance and use a ribbon tape measure like used for sewing. You know the one - the one that the haberdasher has hanging around his neck before measuring you for your suit. They come in cloth and some are plastic coated.
    • momo44
      • 35
      • Augusta, GA, USA.
      You can also measure the diameter of the wheel and the distance from the bottom of the top wheel to the top of the other.
      Then the total length is just:
      Diam x PI(3.14) plus 2*Diam plus 2*distance between wheel
      Example - 14 inch diameter tires, 12 inches between wheels
      14*3.14 + 2*14 + 2*12 =
      43.96 + 28 + 24 = 95.96 inches
      • scoly
        • Jun 2003
        • 395
        Will try both and see what I get. Thanks!
        Steve
          Is it a standard 14", 16" or 18" BS? And does it have a riser?
          k
            • 22108
            In the above the distance between wheels is between the closest points on the wheels.
            Another measure would be
            (3.1416 x diameter) + ( 2 x center-center distance between wheels)
            Probably better than the tape method.
              Isn't it pi x radius-squared for circumference?
                Originally posted by JR
                Isn't it pi x radius-squared for circumference?JR
                No, that's area.
                Which, if this happens to be a Harbor Freight band saw, might be close enough.
                • momo44
                  • 35
                  • Augusta, GA, USA.
                  Thanks Loring! That is a much simpler way of looking at it. Either way, you only need 2 measurements.
                  • scoly
                    • Jun 2003
                    • 395
                    Ken
                    It is a 14" Toolcraft without a riser. Fairly old model. Bought cheap.
                    Loring
                    In your equation (3.1416 x diameter) + ( 2 x center-center distance between wheels)
                    the 2x center-center distance between wheels means what? Confused by "center" and center distance between wheels.
                    Thanks for all the input.
                    Steve
                      Hey Steve,
                      Ckeck the 4th item on this page, it has a phone number for Toolkraft that 'may' still be good.
                      http://farmindustrynews.com/mag/farming_input_24/
                      even better http://www.toolkraft.com/
                        Originally posted by LarryG
                        No, that's area.
                        Rats. It's only April and I've already made my mistake this year.
                        • scoly
                          • Jun 2003
                          • 395
                          Thanks Ken. Had no idea there was a place for their parts. Will be giving it a try.
                          Steve
                          • jackellis
                            • 2638
                            • Tahoe City, CA, USA.
                            I did this earlier today before ordering a resaw blade. I used the same approach Loring recommended because it is much easier than using a tape.
                              Steve, I don't know if Loring didn't see your post or if he hasn't been online. But what he's telling you is to measure the distance between the center of the wheels, and double that. The reason for that is that's where your belt will leave the wheel (the diameter). Hope that clears it up for you.
