What brand/model is this jointer?
  • jussi
    • 2162
    anyone know what brand and model this is?
    bears a strong resemblance to the generic chinese-made jointer like the one Harbor Freight sells.
    One key item is the jointing fence which extends all the way to the right, and positioning of the power switch and the nameplate at the base of the tables.
    • Marlin
      • Sep 2006
      • 34
      Yea HF or maybe Homier.
      Very cheap but if you don;t have much money better then none at all.
      • ragswl4
        • 1559
        • Winchester, Ca
        • C-Man 22114
        I saw one on craigslist that looked exactly like this. Brandname was Transpower. But as LCHIEN said, also looks like HF and probably made in the same factory in China. IMHO, that doesn't make it bad. If it will flatten a board and joint an edge, its a winner.
        RAGS
        Raggy and Me in San Felipe
        sigpic
        • jussi
          • 2162
          It's probably the same one. Was it in Chula Vista. I called but the guy didn't know what brand it was. I saw green and thought it might be Grizzly. Guess not
          • ragswl4
            • 1559
            • Winchester, Ca
            • C-Man 22114
            Wasn't in Chula Vista, Inland Empire I think. Also I think the HF Jointer is on a trapazoidal base so unless it is an older HF.
            RAGS
            sigpic
              The HF has flat, rectangular sheet metal base that's angled out at the bottom. Makes it look trapezoidal if the pic is taken slightly from above.
              • jussi
                • 2162
                I think our right Lchien, It looks to be a 8'' RABBETING JOINTER.
                http://www.harborfreight.com/cpi/cta...emnumber=32966
                • Knottscott
                  • 3815
                  • Rochester, NY.
                  • 2008 Shop Fox W1677
                  The pic says 6" jointer from what I can see, and it looks like a Central Machinery/HF machine, or other close clone. Prolly worth in the $100 range if in good condition, if you're looking to buy it.
                  http://www.harborfreightusa.com/usa/...o?itemid=30289
                    more likely the 6" (or they call it 7" but that may be a stretch), judge from the length of the vertical fence relative to the red blade guard. Apparently they use the same vertical fence for both, but the 8" bed is longer. You can see in the pic of the 8" its much shorter than in the pics of the 7" and our pic.
                    • messmaker
                      • 1495
                      • RICHMOND, KY, USA.
                      • Ridgid 2424
                      I think it looks like the HF 7" jointer. I do not recall it having a knob on the top right corner though.
