modding the DC-650, and neutral vane pics?
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Has anybody modified the Jet DC-650 to accept a cartridge-filter instead of the top bag? I am hoping to get the Wynn, but it is listed to have a 17.5" diameter while the 650 has a 14" wide mouth. Just need to know it is possible to combine the two without too much problem.
    Also, what are neutral vanes? Loring's vanes seem to be universally famous, but i am unable to dig up any old thread with good pics. Threads like http://www.bt3central.com/showthread.php?t=24306 seem to have 'lost' the pics. Loring, any chance you could update the pics or the link?
    - Aristotle
  • Hoover
    • 1273
    • USA.
    I don't know if this will help you, but I got this info from the Wynn site:
    http://www.wynnenv.com/notes.htm
    Scroll down the page, and they mention the Jet 650
    No good deed goes unpunished
      I posted a bit ago that I have lost my ISP and have not yet chosen another.
      If you want the Neutral vane template, relay article, or the BT3 FAQ drop me a PM.
      There was a post a few days ago about (search for) "hot rodding the HF Dust Collector" that had pics of a neutral vane very similar to mine.
      • radhak
        • 3061
        • Miramar, FL
        Thanks. I did see that page, with limited understanding . It talks of the 'orifice plate' that 'should be at the top'; what is an orifice plate? I emailed them, but guess i need to call them.
        Thanks, I shall pm you now. What exactly does the neutral vane achieve?
        - Aristotle
          Neutral vane extends the inlet somewhat so that the incoming air does not mix with/redirect/disturb the airflow from the bottom going up thru the hole in the center ring. Enhances the cyclonic action so to speak.
