WDS Support - Kirby version
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    From this thread:
    http://www.bt3central.com/showthread.php?t=24726
    Excellent way to "fine-tune" keeping the sanding drum parallel to the feed bed.
    Drum attachment: 1/4-20 bolts into tapped holes in the drum shroud.
    All knobs: 1/4-20 studs into tee-nuts.
    NOTE: No MDF was used in the construction of this item!
    Downunder ... 1" = 25.4mm
  • rickd
    • 422
    [ATTACH]2971[/ATTACH]
    That is 'so clean' that it looks like 'nothing' was used in the construction of this item!
    Looks great, as usual, Rod!
    Rick
    rick doyle
    Rick's Woodworking Website
    • SHADOWFOX
      • 1232
      • IL, USA.
      • DELTA 36-675
      All I can say is WOW!! That looks amazing, M8t!
      Chris
        Nicely done, Rod. Had you exprienced some deflection, or was this done by way of prevention?
        • RodKirby
          • 3136
          Great question, JR...
          No (detectable) deflection, but, it was a giant PITA to adjust it "out of the box" to be exactly parallel. Probably not a big issue sanding "narrow" workpieces, but if I do need to sand something "wide", I feel more comfortable now having this support.
          Interesting, that the OEM's are now providing the device?
            A bunch of us guys are gonna sneak in your shop when you aren't looking and spread out some sawdust so it looks like a shop. It's not a wood shop it's an O.R.
            • RodKirby
              • 3136
              As I keep saying - "different strokes for different strokes" - I simply can't work (play?) in a mess. I might also add, that I have never had many of the tool "probems" I've see described - later attributed to dust etc.
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                Very nice Rod. The instant I saw that support on the Steel City model it just made so much sense. I am glad to see you were able to adapt the design to your machine. This is one of the main reasons I was looking at fixed end drum sanders versus open end. Guess that kind of takes care of that issue.
                  [QUOTE=RodKirby;220507]NOTE: No MDF was used in the construction of this item!
                  So, what did you do, Rod? Commission Dave to build it for you?
                  Great idea.
                  • ChrisD
                    • 881
                    • CHICAGO, IL, USA.
                    Nice job as usual, Rod!
                    Chris
                    • RodKirby
                      • 3136
                      Sigh -these guys with a squillion posts figure they can say anything they like
                        Downunder... a squillion = a lot
                        • BearPipes-1
                          • May 2006
                          • 125
                          • Silicon Valley, CA
                          That's going in the FAQ, right?
                          I assume squillions are Imperial units? The idea of a qualitative unit of metric measure is confusing to me. And I'm not sure what a millisquillion would be.
                          Perhaps the number of people actually amused by this particular post.
                          Don't just say no to kickback.
                          • Toolhound
                            • 53
                            Great job, Rod. Youurs looks better than the Steel City version that inspired it!
                            • thestinker
                              • Oct 2005
                              • 613
                              • Fort Worth, TX, USA.
                              Its kind of amazing. Your jigs and what nots look nicer than a lot of my finished projects.
