seeking dust collector help
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    I suppose it depends on which Grizzly and Delta you compare it to. The HF probably compares well to the Delta 1hp DC. The Griz & Delta 1.5hp and 2hp units have larger impellers and should move more air. The Griz is a solid performer and the Delta's consistently test above the competition in comparison tests.
    • Bulkley
      • Oct 2005
      • 86
      • British Columbia, Canada.
      The neutral vane is a good idea.
      Is the stock nine inch ring hole too wide? Has anyone experimented with narrowing the hole?
      • Bulkley
        • Oct 2005
        • 86
        I played around with trying to make a neutral vane, but found it rather awkward bending metal around the built in ring. So, I'm trying an experiment. I found a plastic bucket that is 9 1/2" across the top and 8 1/2" across the bottom. Perfect. I jammed the bucket down into the 9" ring and cut the bottom off a bit below the level of the inport pipe.
        Time will tell. Has anyone else doen this?
          I'm not sure how that increases separation? Doesn't it just act as a liner?
            • 22108
            may not be a bad idea. The concept being that you don't want the inlet air mixing/crashing into the vertical airflow.
            The separation comes from the inlet air swirling downward toward the bottom a bit and then coming straight up the hole in the ring to the top filter. Bigger bits would fall out while spiraling downwards and only the very fines would be carried upwards.
            The neutral vane attempts to achieve this by directing air past the center hole/vertical flow and around the outside of the bottom section. The vertical tube/bucket with no bottom attempts to do similar by isolating the vertical flow from the inlet flow.
