What can you do with a DP?
  • Stick
    • 872
    • Grand Rapids, MB, Canada.
    quote:Originally posted by warrenp
    Not my original idea, but I just finished popping in a 3/4" router bit to rout out the space for a drill press table insert. It allows you to see the work area, bit seems rather risky...not recommended.
    Yeah, lots of things work that aren't recommended. I used to chuck end mills in mine for metal work before I had a mill. Used a cross slide vise and really light cuts. It was ok for very rough work. Work like that's very hard on the DP's bearings though. They aren't designed for side thrust.
    • MBG
      • Apr 2003
      • 945
      • Chicago, Illinois.
      I saw somewhere that you can use the DP to mill grooves/flutes in wood by moving the material relative to the bit against a fence. This is usually a blind cut on a router which requires stop blocks if the pattern doesn't cut through the end of the board. On the DP you can see the exact start/stop points.
      • vinht
        • 391
        • North Andover, MA, USA.
        So for $140 I got myself an....
        Accurate drilling machine
        Mortiser
        Drum sander
        OSS
        3 ring binder maker
        Threaded insert inserter
        Possible planer
        Pen turner
        Bearing presser
        Thread tapper
        Circle cutter
        Dowel sander
        Groove/Flute milling machine
        Wow! Can it do the dishes too?
        A Woodworker\'s Journey
        http://vinht.home.comcast.net
          • 22106
          Mortiser
          Drum sander
          OSS
          3 ring binder maker
          Possible planer
          Pen turner
          Bearing presser
          Thread tapper
          Circle cutter
          Dowel sander
          Now for the serious part. Please be careful. Drill presses don't usually do as much damage as a TS but they can be dangerous:
          Pay attention to:
          • Electrical safety
          • Burns - bits can get very hot. Don't make the mistake of grabbing a hot bit
          • Eye safety - wear your safety glases. Pieces can get thrown, chips fly, work shatters.
          • Put away that chuck key- lots of people have been hit by flying chuck keys inadvertantly left in the side of the chuck. I have my key on a key/badge retractor (trade show or workplace gimme item) so i can't leave it or misplace it.
          • Clamp or brace your work - Freehanding is dangerous - this is especially important in metal working where the bit will grab the workpiece and spin it when it breaks through the back - you can be severely injured by a 10 inch long piece of sheet metal that goes from 0 to 1000 rpm in 0.01 seconds and the outer part will be going about 80 ft./sec DAMHIKT
            The usual safety advice is to brace the "leading" edge of your workpiece if possible against the column or fence so it can't spin.
          • Don't get cut by sharp bits, sharp edges or sharp cuttings
          • Keep the belts covered.
          • Don't wear loose items that can get tangled in the belts or wrapped around the chuck/bit
          • Don't let the elevation handles hit you in the head when you let go.
          • watch out for your fingers and knuckles when using those beam-type circle cutters
          That may not be a complete list but it should get your attention. DPs are under-rated for danger IMHO. Look on the bright side - you don't have to wear hearing protection... at least, I don't.
          • Thom2
            • 1786
            • Stevens, PA, USA.
            • Craftsman 22124
            AMEN!
            DAMHIKT either [B)]
            Thom
            not tellin' in PA
            • Woodnut
              • 605
              • Modesto, CA, USA.
              Mortiser
              Drum sander
              OSS
              3 ring binder maker
              Possible planer
              Pen turner
              Bearing presser
              Thread tapper
              Circle cutter
              Dowel sander
              And:
              Woodnut
              "I should know better, but where's the fun in that?!"
              • Tom Miller
                • 2507
                • Twin Cities, MN
                This is one advantage to having a drill press table like this one, for instance:
                That fence is always there to help control your workpiece.
                And if you do get (or make) a table/fence like this, then I have another "don't" for the long list of "do's and don'ts":
                Don't let the bar of spinning circle cutter smack into that purdy fence. [B)]
                Regards,
                • maxparot
                  • 1421
                  • Mesa, Arizona, USA.
                  • BT3100 w/ wide table kit
                  #23
                  Mortiser
                  Drum sander
                  OSS
                  3 ring binder maker
                  Possible planer
                  Pen turner
                  Bearing presser
                  Thread tapper
                  Circle cutter
                  Dowel sander
                  Add in a cross slide vise and it can do some more serious milling work on wood or metal. Lets not forget you can mount some bonnets and do some polishing. And if it is a radial drill press it can be tricked up to do a few more things.
                  Opinions are like gas;
