What can you do with a DP?
  • vinht
    • 391
    • North Andover, MA, USA.
    After all the DP talk I've been hearing how a DP is used more often than most people think. I can think of three different reasons why I might use my soon to be DP...
    • Normal drilling operations
    • Drilling out mortises
    • Sand drum
    Are there any other uses? Also, this may sound stupid but I have never owned or operated a DP before, can I use any type of bit that will fit in the chuck? Can I use the same bits from my hand drill on the press?
    Thanks,
    Vinh
    A Woodworker\'s Journey
    http://vinht.home.comcast.net
  • tfischer
    • 2349
    This is a good thread. I was wondering the same thing when reading the comments from the other thread.
    I know HF and others have a kit that turns a DP into a oscillating spindle sander. Not sure how good it is, but with my space concerns I'd probably eventually get one, since there's little chance of having room for a dedicated OSS. As I understand it these are usually better than drum sanders.
    -Tim
      One of the advantages of a drill press is not necessarily all the "new" things that you can do but the accuracy with which you drill holes versus using a hand held drill.
      To me, the difference was similar to moving from a circular saw to a BT3x.
        Yes, this is a good thread. It's why I asked this question in Vinht's previous thread. So I'll chime in, all I've really done with it is increase the accuracy of standard drilling operations. It's made doing things like adjustable shelves much easier for me. Constant depth, ect...
        I'd LOVE to know if there are cool things to do with it that I've not discovered, so I hope there are many replys to this from some of the more experienced guys.
        thanks,
        • jdoolitt
          • Jun 2004
          • 124
          One cool thing / project you can do, is build a 3 ring binder drilling jig. Use it to punch holes which are too big for normal hole punches (like your TS manual) into a binder. The plan is in a recent Wood Magazine, IIRC. Took about 10 minutes to put together.
          Its a fun easy project. You can get by without the jig by simply putting binder paper over what ever you want to punch - and mark where you will be drilling though - - but whats the fun in that.
          • bmyers
            • Jun 2003
            • 1371
            • Fishkill, NY
            • bt 3100
            One DP trick I've seen is using it to install threaded insert perfectly straight into the stock. I saw this tip in a jig book to install threaded brass inserts into an adjustable box joint jig. Double nutting it onto a bolt with the head cut off chucked in the DP. Then lower chuck and turn by hand into the stock. When you really need them straight, it's a good way to do it.
              Exactly my sentiment.
              It makes your holes absolutely perpendicular to the wood surface. You can make a series of holes using a fence that are absolutely straight in a line. You can do repeatable setups easily. You can do counterbores and stepped holes perfectly centered on top of one another. You can make holes of perfectly repeatable depth w/o having a stop collar mar the top of your wood. I love to put a setup bar ay 1/8th inch on the drill table and set the depth stop so thatthe bit just touches the bar. Then when I drill the wood I know when the bit stops its leaving exactly 1/8" of wood at the bottom of the hole.
              When you take a 2" thick piece of wood and mark a spot 1" from one edge and 1 inch from the adjacent edge on both top and bottom, with a drill press you can drill a hole from the top that will go exactly thru the mark on the opposite side. With a four-inch thick piece of wood you can drill 2" in from one side, flip the wood over and drill two inches in from the other side and the holes will line up perfectly. I challenge you to do that with a hand-held drill. This may or may not seem important to you but maybe you are building a toy car (or a pine derby car for boy scouts) and drill the axles through. Do you want it to sit flat on the ground or rock? do you want it to roll in a straight line or curve when pushed?
              Just about anything you can chuck up in the 1/2" chuck of a drill press you can turn. I sometimes chuck up rods and sand them with a strip of sandpaper if I need a smooth rod.
              I'll go on to say I'm not fond of using drum sander attachments in my DP - I don't feel that the lateral load is good for the DP.
              • vinht
                • 391
                Great analogy Hank! I never thought of it that way but certainly makes me feel good that I pushed the DP to the top of the list. I'm going out to pick up my DP today! [^]
                Vinh
                • Jim Boyd
                  • 1766
                  • Montgomery, Texas, USA.
                  • Delta Unisaw
                  I have used my drillpress as a press putting together rings of segmented turinings. It has been a thickness sander. I have an attachment that I have not used yet that makes it a planer. I have used it to assist in starting taps straight(by hand of course!)
                  • Stytooner
                    Roll Tide RIP Lee
                    • 4301
                    • Robertsdale, AL, USA.
                    Stick your pen turning mandrel in it and turn pens without the expense of a lathe. You would only need a concrete nail drove into a board clamped to either the table or the base. Clamp it to the base and swing the table to the side with another board clamped to it for the tool rest.
                    Be careful that you don't wind up with the same problem as this fellow though. [8D]
                    • BrazosJake
                      • 1148
                      • Benbrook, TX.
                      • Emerson-built Craftsman
                      Bingo. Now, I don't currently own one, but it is next on my shop priority list. If like me, you're into shop-made accessories and want to do things yourself, they're a almost necessity. I find myself wishing I had one constantly. You really need one for things like like drilling router plates and other operations where you need holes perfectly positioned and angled trhough the workpiece.
                      Also, Forstner bits should only be used in a press. You can fudge it by starting a hole with a slighlty undersized spade bit then tapping the right size forsnter into the hole to finish, but it's a pita.
                      I've got my eye on the Griz BT Radial DP for Xmas.
                      • Troy Webber
                        • 115
                        • Normal, Illinois, USA.
                        If you do your own tool repairs like I do,a drill press works pretty good for pressing bearings.
                        I recently bought some American made NSK bearings to replace the noisy Chinese bearings in my Delta dust collector.I built a jig and used my drill press to press them.The front bearing was pretty large,but it worked great.
                        I've also seen some woodburning kits that press a logo onto wood projects using a drill press
                        • Stick
                          • 872
                          • Grand Rapids, MB, Canada.
                          ya beat me to it. I used mine for that for years until I got a hydraulic press and an arbor press.
                          DP also is great for (unpowered) tapping threads in metal. I've used mine as an improvised lathe too, and as an improvised punch press for sheet metal work. Also pretty tough to drill large holes in steel with a hand drill. And just try making a new cross hole in a clevis pin or the like with a hand drill!
                          My old DP probably gets nearly the most use in my shop, followed by the welder and an assortment of grinders, then the metal lathe, then the milling machine. Sorry but the BT, the RAS and the CMS are WAYYYY down on my list! LOL!
                          • Tundra_Man
                            • 1589
                            • Sioux Falls, SD, USA.
                            Didn't see this mentioned above, but you can also use it with a circle cutter to cut large holes, i.e. for clock faces. Can't spin one of those with a hand drill (and live to tell about it, anyway.)
                            Have a dowel that's just a hair too tight? Chuck it in your DP and sand it down to make it fit.
                            Have a multiple piece project where a hole has to be drilled in exactly the same spot on each piece? Clamp a framing square to the table so that you can slide the pieces into the corner and precisely drill the holes.
                            Saw a number of people mention drilling absolutely perpindicular holes, but you can also tilt the table to drill very accurate angled holes.
                            I love my drill press; I use it on nearly every project.
                            Terry
                            • warrenp
                              • 124
                              • Kentucky, USA.
                              Not my original idea, but I just finished popping in a 3/4" router bit to rout out the space for a drill press table insert. It allows you to see the work area, bit seems rather risky...not recommended.
