Ryobi WDS1600 drum sander
  • mikeps
    that should probably work, looks like basically the same machine. The main thing that I wanted was just how to properly put the paper on the drum. I'm sure it's not difficult, but I have read of some people having the paper rip on them. I'll PM you and give you my email address. Thanks for the help.
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Manual e-mailed...
      Regards - Rod
      Downunder ... 1" = 25.4mm
      • xwelder
        Handtools only
        • Mar 2011
        • 1
        Sander clip by height adjuster
        I was replacing my first belt and thought I had the sandpaper insalled the same manor as the one I took out but when I started the wood through it pulled out on the end of the drum next to the height adjuster. I can't see well enough behind there to tell how the sandpaper is supposed to grip. Maybe when the wood grabbed it removed something because I can't see whats supposed to hold it. Any help would greatly be appreciated.
        xwelder
        • RodKirby
          • 3136
          xwelder
          Replied to PM.
          There are spring-clips inside each end of the drum - you have to feel around inside to find them. Unmistakable grip once you find them.
          • cork58
            • 365
            • Wasilla, AK, USA.
            You might give is a look for the paper. http://www.industrialabrasives.com/
            I haven't bought from them yet but when you get to looking these guys are really into the sanding business.
            My sander is a perfromax 16x32 so no help on your other guestions, but I just went through a real experiance with mine. The locking collars on the drum came loose on the motor side. Before I figured out what was wrong it ate the shaft part of the drum. I was able to repair it and all is ok now but for now on I'll be checking those set screws more often.
            Cork,
              I bought a 52 yard roll of 120 grit. Don't remember if it was from Industrial Abrasives or Super Grit.
              Two tips if you are going to cut your own strips.
              1. Layout a cut line on the floor so the length will alwys be right.
              2. make a template for the ends and mark which side is up. I have found strips from Ryobi that were cut backwards, and they are supposed to be machine cut.
              • natausch
                • Aug 2009
                • 436
                • Aurora, IL
                • BT3000 - 15A
                Stop making me jealous. Been in the hunt for a drum sander for about a year, casual and slow paced but still frustrating. Current one I'm stalking is a Performax 16/32 but the guy selling won't budge on the asking price posted on CL for the last two months.
