Drill press speed
  • wreckwriter
    • 449
    • South Florida
    Drill press speed
    So I got my new DP today Got it all set up no problems. Checking it out one thing that surprized me me is the complexity of changing speeds. I guess I expected a switch
    Most of my work will be softer wood, generally pine but occasional some light aluminum. Is there a good "default" speed for this or do you really find yourself moving the belts around often?
    Thanks, as always!
    http://www.wreckwriter.com/
  • sacherjj
    • 813
    • Indianapolis, IN, USA.
    I change speed pretty often. Soft wood with a twist bit is better drilled at 1800. Aluminum should be drilled much slower. Once you get used to your drill press, you can detension the motor, swap belts, retension in a couple seconds.
    Joe Sacher
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Take a look at this...
      http://www.woodmagazine.com/wood/sto...ry/data/85.xml
      Downunder ... 1" = 25.4mm
      • Tom Miller
        • 2507
        • Twin Cities, MN
        Based on a suggestion from someone, somewhere, I no longer detension the belts to change speed. Instead, I just "walk" them (is that the term?) on and off the pulleys. That speeds up the process.
        I'll give a little leeway in speed for a bit not to have to change the pulleys, but not much; especially for the larger bits that should be run slower.
        Here's a good DP Speed Chart, BTW.
        Regards,
        • RodKirby
          • 3136
          Tom - that's the one I was looking for (and have). WOOD have changed the layout etc.
          • Hoyden
            • Jan 2005
            • 122
            • Twin Falls, ID, USA.
            try this Wood magizine Drill Press speed chart. I know its a long one but will take you to the speed chart page.
            http://www.woodmagazine.com/wood/sto...ols.xml&page=2
            PawPaw
            • wreckwriter
              • 449
              • South Florida
              Thanks guys. I'm sure once I do it a couple times I'll be fine; just looks kinda confusing under the cover....
              • Tom Miller
                • 2507
                • Twin Cities, MN
                I wondered what happened to that chart -- they ruined a good thing! Luckily someone had the sense to save it in pdf form and host it. (I googled it.)
                Tom (wreckwriter): Another thing I found useful is to somehow mark the current speed on the outside of the pulley cover. I have magnetic-backed labels -- one for each speed -- that I keep inside the cover. When I change pulleys, I put the new speed label on the front of the cover.
                Regards,
                • wreckwriter
                  • 449
                  • South Florida
                  Regards,
                  Good idea. I happen to have a roll of magnetic tape I believe. Thanks!
                  • kmk
                    • 415
                    • .Portland, Oregon
                    Found this when I was browsing rockler website...
                    http://www.rockler.com/product.cfm?page=10675
                    • wreckwriter
                      • 449
                      • South Florida
                      That would be handy and the price is right. Next time I order from Rockler I'll toss one in. Thanks!
                        Thanks, as always!
                        First of all did you see this i posted a couple of weeks ago, about the importance of the right drill speed?
                        http://www.bt3central.com/showthread.php?t=20132
                        Second, I find it pretty easy to change speeds on my drill presses.
                        Flip the cover open, loosen the wing knob that holds the belt tension.
                        On one, there's a lever that deteniosns the belts, on the other, I just pull the motor forward a half inch, it's on a hinge on one side.
                        Change the belt(s) - one has one belt (5-speed DP), the other 2 belts (12-speed DP).
                        Push the motor back using the tension lever or just push the motor mount, I find it doesn't have to be real tight. I can change the speed in under 20 seconds, I think.
                        Worth it.
                        Anyone else besides me using two drill presses?
                        • wreckwriter
                          • 449
                          • South Florida
                          Worth it.
                          I did see that but didn't have a press at the time so didn't pay as much attention to it as I did rereading it just now.
                          I'll check mine out and practice changing it. Thanks everyone!
                          • wreckwriter
                            • 449
                            • South Florida
                            OK, just went out and changed the speed. Not as difficult as it looked at first glance Also printed and laminated the speed chart. I'm sure you guys saved me from ruining some pieces.
                            • kmk
                              • 415
                              • .Portland, Oregon
                              I assembled my Ryobi DP120 today and when I was installing the belt I noticed the speed chart on the inside of top cover that encloses the pullies.
