Nailer Recommendation
  • killin5
    • 11
    • Lake City, FL.
    I am in the middle of a few home renovation projects. One that I see coming up quickly is the installation of Chair rail. This of course may lead to new baseboards and some Crown Molding. I have never been a fan of doing molding work mostly because of nailing through the metal edging on the sheetrock corners. I have an air compressor that I can borrow. And if that doesn’t work out, I might be able to play the angles and pick one up. So I’m looking for a nail gun. We just moved, so we are in budget mode. I have never used a nail gun before. I need some recommendations.
    These are the ones I’m looking at
    Porter Cable BN125A Factory Reconditioned 18 Gauge 5/8" to 1-1/4" Brad Nailer Kit $44.99
    • Uses standard 18 gauge brads from 5/8" to 1-1/4" long
    • Special hardened driver blade
    • Tool-free jam release mechanism designed not to block line of sight
    • Strong & light weight die-cast aluminum body
    • Hard coat anodized magazine with visual reload indicator
    • Contact safety located behind the driver guide for driving brads in tight spaces
    • Tool-free depth-of-drive adjustment for exact setting of nail head
    • Removable rubber nose cushion and directional tool-free exhaust port
    • Magazine capacity: 100 brads. Operating pressure: 70-120 psi. Firing modes: Sequential fire.
    • Includes: Nailer, 1/4" male quick plug with dust cover, rugged carrying case, box of 1000 brads, oil and operating manual
    http://www.toolking.com/productinfo.aspx?productid=285
    Grizzly H5527 18 Gauge Brad Nailer Kit $29.95
    http://www.grizzly.com/products/H5527
    • 18 ga. Nailer accepts up to 100 5/8" - 2" brads, operates on 70-110 PSI, features a 360 degree adjustable exhaust and only weights 3.5 lbs.
    Grizzly H6332 Air Nailer $23.25
    http://www.grizzly.com/products/H6332
    • Shoots 3/8" - 11/4", 18 gauge brad nails 60 - 100 PSI operating pressure 100 piece nail capacity Quick release nose piece clears jams fast Single shot or bump fire mode Includes durable plastic case Weighs only 2.75 lbs.
    I’m leaning towards the PC one because it has an adjustable depth setting.
    Am I thinking to small/cheap?
    Any advice here would be appreciated.
    John
    If you want the most versatility, get a 2" brad capacity rather than limit yourself to 1.25".
    Avoid combo nailer/staplers because of the driver dent.
    I'd take a long look at the Harbor freight 18ga 2" brad nailer that goes for $20 and sometimes goes on sale for $15, its a lot of bang for the buck, functionally its all there, seems to be reliable for users here, not the most beautiful and doesn't have a depth control other than adjusting the air pressure.
      I have had a PC BN125 for years and it has never failed me.
      • kmk
        • 415
        • .Portland, Oregon
        I have Porter cable air compressor, brad nailer, finish nailer and stapler package and no complaints! I used it on expensive cabinet project and they worked great. No misfires. No jams. I'm planning to buy their pin nailer as well.
        The package deal was awesome. I think HD still has it. With $35 GC, it will be $295. If you use any coupon, it will be excellent deal I think.
        • Shipwreck
          • Mar 2005
          • 85
          Brad nailer
          None of them..........To shoot chair rails and base board, you need at least a 16 ga. brad nailer. The 18 ga. brad alone will not hold the material properly, unless you help it out with glue/adhesive.
          In most cases I have used a 16 ga. nailer and have had excellent results. A 15 ga. nailer might be the best all around nailer for the tasks you have noted.
          I have the same BN125A nailer that you are inquiring about. Its a great little shooter, but its more suited for lighter gauge work.
          I have seen guys use a 18 ga. nailer to put in pre-fab door frames, chair rail, base boards, but I would not advise it to anyone,.............. Sooner or later they will work loose.
          There are those who might argue with my opinion, but I work in the drywall industry, and follow up behind the trim guys all the time. They ALL use either a 15/16 ga. nailer.
          • mschrank
            • Oct 2004
            • 1130
            • Hood River, OR, USA.
            All I can add is that I agree with the comments above.
            I have the Porter Cable 18 ga nailer. I've used it extensively and never had a misfire or jam.
            But, it IS too small for the trim work you mention. I've used to while replacing most of the trim in my house, and the 18 ga 1-1/4 brads just aren't stout enough or long enough to do the job properly. By the time you shoot through 1/2" or trim and a 1/2" of drywall, there isn't much brad left to secure into the framing.
            OK, I guess I can add some more: If you haven't used these nailers much, be very careful of where your other hand is while shooting brads. Seems the most convenient spot to hold the trim is exactly the wrong spot when the brad decides to deflect due to woodgrain or whatever. AMHIK
              I also have the porter cable set. 18g, 16g, and compressor. Both nailers have worked well for me for the past couple of years.
              • Hoyden
                • Jan 2005
                • 122
                • Twin Falls, ID, USA.
                I have the porter cable 16 ga and tradesman 18 gage and a pin nailer all are excelent for thier uses. but you do need to be able to shoot 2' nails to put up trim and have it hold. that said i'm sure that we have all used less at different times and it worked, maby not well though.
                PawPaw
                • killin5
                  • 11
                  • Lake City, FL.
                  Thanks. It is always hard to buy a tool you have never used. Well actually it is pretty easy. It is even easier to buy the one with the features you needed once you figured out what they were (just harder to justify). That is how I ended up with my BT3.
                  So I should be looking for a 16 ga. nailer.
                  I haven't researched these. What would be some good options here? I suppose this will bump the price up quite a bit.
                    Well, I got the PC kit because I didn't have any of the needed stuff (same sitch you are in). The brad nailer is useful for furniture projects, and the finish nailer is useful for trim work. The compressor is small and light enough to fairly easily move from room to room.
                    If you can swing it, I'd recommend it.
                    • RmeDad
                      • 231
                      • Scottsdale, AZ
                      PC has been very, very good to me!
                      I also have the PC combo kit and I am very pleased with it. I ditto Keith's remarks.
                      Jack
                      Throughout my racing career I was constantly reminded of this: "Keep the pointy end forward and the shiny side up!"
                        I agree. 15 or 16 ga is the one to use.
                        • jhart
                          • 1715
                          I also have the PC combo kit, but purchased before there were the combo kits. Got the compressor and BN 125 first, then the finish nailer and then the framing nailer. Never have had a problem with any of them.
                          That combo kit for $299 is a great deal.
                          The compressor has framed a 3 car garage, framed a 3 story porch, roofed 2 houses, used to spray texture on 2 ceilings, spray paint ceilings and a host of other things.
                          The portability of the compressor is the thing I love about the whole setup.
                          • Tarheel
                            • 114
                            • N. Carolina
                            I too have the PC Compressor combo with the brad, finish nailers and stapler. The brad nailer is great for holding joints during glue-ups and the finish nailer is great for interior woodwork - ie chair rail, baseboard etc. I have not had a jam with the nailers either.
                            One caution with the compressor though. It is kind of noisy which I understand is typical of oiless compressors,
                            Wayne
                            • Sawatzky
                              • 359
                              • CA
                              I have never used PC nailers, but I know they are good. I have a Bostitch 18 ga. nailer and a Bostitch 15 ga. nailer. If possible, I would get a 15 guage rather than the 16 guage. the nails are stronger, and there is nothing a 16 guage nailer can do that a 15 guage nailer won't do. I feel with nailers, get the best you can because it will pay off in the long run. My Bostitch 15 guage is older, but works great.
