Image-Posting Tutorial, Please?
    Would someone be willing to walk me through the exact steps required to post pictures within forum messages?
    First item would be the optimum size in pixels, to prevent the dreaded Annoyingly-Wide-Screen Syndrome.
    Do I need to upload the pictures to some external hosting service? At the moment I subscribe to no such service but could set that up, if it's necessary. If so, a recommendation of who to use would be helpful.
    Thanks much to whoever can help.
    Step 1 - have the picture on your computer. If you took it with a camera with more than 1 mega-pixels it probably needs to be resized. I would suggest editing size with the PAINT.EXE program provided with virtually all Windows computers. found under START->PROGRAMS->ACCESSORIES->PAINT. Open the picture with FILE->OPEN->, and view at 100%. Click on IMAGE->ATTRIBUTES to see how big it is in pixels. Use IMAGE->STRETCH&SKEW to change the size, I suggest using
    50%, 33%, 25% or 20% (1/2, 1/3, 1/4 or 1/5) to get the cleanest resize and a picture size of around 300 to 400 pixels on a side. Use the same Horizontal and vertical stretch. Say the original image was 1600 x 1200 pixels then a 25% reduction in both H&V would give 400x300. The actual picture size will be 1/16th of the original size!
    Don't forget to save it (select JPG as the type) and don't use punctuation or spaces in the name, it's OK on the PC but BT3central doesn't like it. The size savings (your pics should now be under 100K) will allow you to store many pics on the space BT3central has allocated for you as well as make it easy to download and view for others.
    Step 2 - Uploading to BT3central (no external web site needed) - Create a message (e.g new topic or reply to topic. Quick reply won't allow posting pics). At the message entry window just below the main text area you will find a "Attach File" in the left column. Just to the right of that there is an "Upload" link. Click Upload and fill in the File Upload box that appears with the name of the file on your computer. You can use the BROWSE button to select from the files on your computer. Uploading a pciture will also insert it into the message txt at that point.
    You can do this for as many pics as you like.
    Note: don't use the ATTACH button, this will cause a second insertion of the picture. If you wish to insert a picture you've uploaded before for another post, you can use the ATTACH button to select it.
    You may wish to click <Preview> at the very bottom of the message entry window to see how it looks before you post it.
    That's it!
      Thank you kindly, Loring. I know how to resize pictures (longtime user of Paint Shop Pro) but I didn't know about the filename issues. I'll give it go later today, if I get a chance. Thanks again!
      • Turaj
        • 1019
        • Toronto, Ontario, Canada.
        • BT3000 (1998)
        Loring
        Thanks for the instruction!! It is very clear and certainly helpfull! (just used this feature for the first time)
        Turaj (in Toronto)
        • dlminehart
          • 1829
          • San Jose, CA, USA.
          I'd add to Loring's Step 2 that "Create a message as usual" means using the "New Topic" or "Reply to Topic" link. The "Quick Reply" box at the bottom of each thread is a text-only shortcut that doesn't allow photo uploading.
          - David
          • gmack5
            • 1972
            • Quapaw, Oklahoma, USA.
            • Ryobi BT3000SX & BT3100
            Just my opinion, but I think this thread needs to be a "sticky" in the "Getting Started" Forum. []
            George
            • cobob
              • 252
              • Rolla, MO, USA.
              I'm replying frm a distant site so i CAN find it again at home. I agree this need to by in the 'best of' forum
                it would be, but, unfortunately, it describes how to insert pictures for the
                old forum software which was replaced early in 2006 with new forum software. The date of the original post and most replies in this thread was July of 2005.
                • RayintheUK
                  • 1792
                  Have a look here and see if this helps.
                  Ray.
                  Did I offend you? Click here.
