What happened?
  • jonmulzer
    • Dec 2007
    • 946
    • Indianapolis, IN
    What happened?
    Things were painfully slow for a while and I received a database error last night like when the forum went down last time. Equipment malfunction? Any update on when we are getting moved to the new server?
  • TB Roye
    • 2969
    • Sacramento, CA, USA.
    Bet it was weather related, probably power outage. You guys east of the Missisippi have been having some real bad weather. Sam probably had a power outage and it took awhile to reboot the server.
      • 22060
      Not likely, the server was still responding (i.e. it was not a 404 error, site not found which is what you get if the server is offline) but it was a VBulletin message (the software the forum runs) which said specifically that the database was corrupted. Thus the server was on but it said it was dazed and confused.
      • TB Roye
        • 2969
        That's right it said Database error, sounds like me sometime confused.
        • Sam Conder
          Woodworker Once More
          • 2502
          • Midway, KY
          • Delta 36-725T2
          Hard drive filled up with log files. Apparently my autozip routing hung a few weeks back and it went unnoticed.
          Sam Conder
          BT3Central's First Member
          • TheRic
            • Jun 2004
            • 1912
            • West Central Ohio
            I noticed people have posted early this AM, and afternoon. I finally got on a few minutes ago, tried it several times today, last time it errored out on me was about 20 minutes ago. Tried the refresh several times, and even cleared my cache this afternoon.
            Last night I got kicked off in a middle of a post, well at least I can breath again.
            Ric
              Yeah, I've been trying off and on to get on all day. Finally made it. Whoopee!
              • kramer katt
                • 375
                • SO CAL, USA
                • BT3100 and Craftsman 100
                forum problem
                Boy you guys get a little jumpy when your out of touch here.
                I noticed also that the time stamp on current posts does not say "today" as before but the numeric date as in 3/9/2008 One day old still is "yesterday"
                Maybe there is a daylight savings bug going around
                kk
                --Albert Einstein
