Shop floors
    Shop floors
    I have seen it mentioned more than once that wood floors are easier on the feet. It got me thinking... are they really easier on the feet?? Concrete is hard, true, but so are solidly framed plywood floors. If there was enough "give" in the plywood floor to cushion us as we walked, then the floor would be certainly deficient and certainly no tools could roll across the floor as the floor would be sagging under its own weight!
    I know that you have both read and heard this yourselves. Care to comment? Especially anyone that has worked on both types of floors!
    Thanks
    For me, I would highly doubt that a solidly build wooden floor would offer any comfort beyond the psychological comfort of surrounding ourselves with the organic feel of wood, instead of the synthetic, harshness that is concrete...
    I would think it would be far more important to be wearing proper, supportive footwear in the shop than to have a wooden floor.
    • bigstick509
      • 1227
      • Macomb, MI, USA.
      I've got these in the shop/garage. They cover both sides of the 2 1/2 car shop. They have been down about 6 years with no problems. Very easy on the legs and feet and have saved damage to dropped wood and tools.
      • Eric
        • Jun 2003
        • 653
        • Cocolalla, ID
        • Grizzly G0691 & BT3100
        I've got a plywood floor in my shop and use the cushion mats from HF in areas where I stand for periods of time.
          My floors have been concrete, but at some stations, a sheet of plywood. I can't describe it, but plywood/wood seems easier on your feet. The only way I can explain the difference in hardness, is if some glass item hits concrete...it's a gonner. Same item may take the drop on plywood.
            • 2813
            My basement has a tendency to get damp after four or five days of continuous rain. Not a good thing if you'r working with electricity, but mostly it's a real problem if you've left your tool bag or some wood pieces, or just about anything else in contact with the floor.
            Therefore, I use "Dri-Core" floor panels, which are roughly 2-ft square, treated panels with a PVC backing, which strands-off the concrete. The stand-off surface of the PVC allows for some ventilation, as well as providing both a moisture barrier and a bit of cushioning under the 3/4 T&G panel.
            Over a few years I've managed to get enough panels to almost completely cover the shop and laundry areas of the basement. Very easy on the legs, and yet supportive of the bench, and stationary tools and I can easily roll my vac, tool cabinet, BT, and router table around the shop.
            Technically, I can't give you numbers on any cushioning effect for the old legs. But, I can tell you for certain that if it "feels" better. Perhaps it's not so much cushioning as much as it is simply more impact forgiving.
            • jking
              • 972
              • Des Moines, IA.
              Concrete does not give any measureable amount, wood floors do enough to make a difference over time. Try this for a test: Take a hammer and hit a concrete floor several times. Then, hit a wood floor the same number of times. Now, which one would you rather do on a continuous basis?
              The other thing to keep in mind is that concrete floors tend to be colder than wood. This can also be a factor in certain climates.
                If one were to jump off the top of the Empire State Building, it's likely that plywood would be a softer landing than concrete.
                  Good thoughts folks, I have to agree that there is something about working on wood versus concrete, but I couldn't really reason it out.
                  Jking has a great point, our knee joints are like two hammers getting pounding together as we walk across concrete which is not flexible while the wood is hard, but has some elasticity to it! That's the perfect term in my head that makes me understand the difference better, elastic vs inelastic. Thanks for the road to the thought :-)
                  Mike, great to see you post and pics to boot! That is really cool to hear that those have worked well for you and long term too. Where did you find the edging material? I have seen sale prices recently at HF on their mats, don't know the quality, but the price seemed really good.
                    • 22109
                    i think Jkings points are correct.
                      When I did a lot of running (in my younger days), I tried to run on asphalt when possible rather than concrete sidewalks. Even between these 2 materials there is a difference in the effects felt on the joints.
                      • bigstick509
                        • 1227
                        • Macomb, MI, USA.
                        The edging like the mat squares are from HF. I usually waited for sale price of around 6.00 before buying. The yellow edging was a bit harder, only available online from HF but fit a discontinued sku mat. I ordered multiple packs and hand cut to fit the new mat configuration. A pain in the **s, but using the new mat as a template helped.
                          Thanks Mike and super glad to hear that they survived 6 years, wow! Does shop equipment roll over these or are they too soft for that?
                          • bigstick509
                            • 1227
                            • Macomb, MI, USA.
                            Most everything in the shop/garage is on wheeled bases. BT3, double stack tool chests,band saw and drill press all roll fine with minimal extra effort.
                            • Daryl
                              • 831
                              My floor seems to always be covered by a layer of saw dust and shavings. I think it is easier on my feet than being neat.
