Dust hoods for older jointers
  • WoodMan
    Handtools only
    • Oct 2012
    • 3
    I have an older model jointer that has no dust collector hood and I want to hook it into my pipe system. There is a hole under the cutter where the chips fall onto the top of the motor. There is not room between the bottom of the jointer stand and the motor to install a manufactured dust hood. Any suggestions?
    what you often see is they put a ramp or chute over the motor to deflect the shavings off the motor. Then at the bottom of the chute a bulkhead 4" hose connector is mounted over the end of the chute.
    It doesn't catch everything but most of it. JOinters ca make a lot of fluffy shavings.
    • Cochese
      • Jun 2010
      • 1988
      Can you drop the motor? I did just that yesterday to mine to put a hood in with a hose.
      Link belt from HF took care of the additional length.
      Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
        One fix was just a removable box like this. The more common way was to create a way to channel the chips out with a ramp of sorts as done here.
        http://vintagemachinery.org/
          I built a custom base for my 8" Rockwell Delta.
          http://home-and-garden.webshots.com/...56381500ldRbEO
            Here are the tugs maneuvring Pappy's jointer into the Playpen.
            • Cochese
              • Jun 2010
              • 1988
              Big E never looked better.
              • aiyou
                • 110
                • Charlotte, NC
                Pappy..
                Not intending to hijack the thread, but might you have any more details/plans on the actual mobile base component? It looks similar to a roll-around tool base from Wood, but with mods to the cam-lever mechanism.
                I presume the mods improve the lifting capability of heavier loads?
                Is there a lever on either end?
                Thanks
                Rob
                  Originally posted by aiyou
                  Pappy..
                  Thanks
                  Rob
                  Got a lot going on today but I will try to get another thread started on the lift mods with some pictures later this evening or tomorrow.
                  Quick answers to your questions for now:
                  1. It is based on the Wood magazine mobile base.
                  2. The mods to the lift lever made it easier to lift heavier tools but the main reason was that in the original design by Wood the pivot bolt kept backing out, making the lever loose.
                  3. The lever on the left is was in the way of attaching the DC hose to the chip chute. (Design screw up on my part.) Easier to remove the lever once it is on the feet than to go back and rebuild the entire base!
                    Wow, Pappy I had not seen your jointer before. You did an excellent job not only on the design and build of the base, but on restoring the old Delta. That top looks flawless!
                    • WoodMan
                      Handtools only
                      • Oct 2012
                      • 3
                      Sorry for the delay in reply. After reading what you said I went back and took another look. I was able to drop the motor but not quite enough. So I am going to reattach the motor in a different place. All it will cost me is a new belt.
                      I put a dust shoot on yesterday that I got from Woodcraft. Put in on with epoxie. The sucker is never going to come off.
                      • WoodMan
                        Handtools only
                        • Oct 2012
                        • 3
                        I dropped the motor and got a new belt and walla. All fixed. The dust hood now works perfect.
