Which vise for face, tail?
    • 22106
    I have two woodworking vises stashed away over the years.
    Now finally building a workbench.
    One is a Shop Fox 9" (width) with pop-up dog which is the bigger one.
    The other is a 7" (width) Record vise, also with pop-up dog.
    They have about the same capacity, the Shop Fox maybe an inch more.
    Which would you put as the face (front, left) vise, and which on the tail (right end) of the bench? and why? Or does it matter?
    I'm leaning toward the bigger Shop Fox on the tail location.
    If I had only one vise, I'd mount it as a tail vise. The decision might be made as to where you would want a larger vise, and/or what kind of work you will be doing. With two to pick from, if after much use you determine that they need to be switched, you will at that time know that your decision is based on a variety of criteria.
      I tend to use the face vise more, so if either of those vises is a quick release, I would put that one on the face.
        • 22106
        they're both Quick release type.
          Is one smoother / nicer to use than the other?
          • Mr__Bill
            • 2096
            • Tacoma, WA
            Traditionally the wider vise is the face vice. The face vise often holds work in it's jaw while the tail vise holds the work against a dog on the bench and in that use the width is not relevant, often just a dog sticking up.
            Currently the vise on my bench consists of pipe clamps that can be arranged in several places with a heavy board as a face, and I have found that what I use most often is two clamp placed about 18" apart on the face. For the last year or so I have been practicing making hand dove tails and this allows the board to pass between the clamps and still be held tightly.
            Another factor you may consider it how far each sticks out when closed and will it be in the way when doing other things that do not require the vise.
            My bench/assembly table was patterned on this Blum Bench.
              • 22106
              looks like the 7" vise has slightly better finish and fit but overall they've got the same feature set - pop-up dogs and quick release.
                Maybe it's down to flipping a coin.
                  Sounds like it to me...
                  Heads the 9" goes face, tails it goes, well.. tail...
                  • vaking
                    • 1428
                    • Montclair, NJ, USA.
                    • Ryobi BT3100-1
                    Lee Valley sells dual handle tail vise which is usually made the full width of the bench. Lee Valley bench is not common. It usually has only a tail vise. The more traditional scandinavian type bench has a small tail vise. Tail vise has no real face, just bench dog and single raw of holes along the front edge of the bench. It also does not need large opening since all you need is to have an opening the size of space between dog holes. The front vise, on the other hand, is used more often to clamp the object between jaws, not with dogs. So for traditional bench you want to put bigger vise to the front.
                    Alex V
                      I'd put the bigger one on the face. I've found having a little more depth and jaw width to be a good thing. I two old 9" Wiltons on mine. One on the left as a face and the other on the right end as close to the front as I could get it as the tail. I mainly use the tail vice with the dogs. I don't clamp much in it proper. It might be different if I had a big twin screw and room to work on the end.
