My new HF DC seems to have caster shanks that are about 1/2" too short. When the casters pivot, they can hang up on the edges of the platform to which they're attached. Did I hook them up wrong? Anyone else have the problem? Any easy way to fix it?
HF DC won't roll without casters catching
- David
“Be yourself; everyone else is already taken.” -- Oscar WildeTags: None -
yeah that problems been well documented here. You should have searched for "HF DC problems" or something like that before assembling anything HF'ish.
Some guys complain they have black streaks all over their shop because of this!
I caught it while assembling and put 3/4" wood spacers under each wheel and used 1/4-20 x 1" bolts and nuts instead of the supplied metric ones.
Others just took some big pliers or hammer and bent the lip outwards as needed to avoid interference (works, but must look like sh*t, tho).
Another solution - You can probably break off the locking levers since its nearly impossible to lock it anyway.
apparently they changed wheel suppliers and/or part numbers from non-locking to locking type somewhere in the manufacturing history and never took care of the resulting problems.
Probably some guy in the purchasing dept said we can buy these other comapany's casters with locks for $0.50 less per DC and they have the same hole pattern.
In a proper manufacturing organization there is a "Change Review Board" or similar composed of engineers and managers whose duty it is to review proposed changes in suppliers and materials to see if there is any possible effects - and would assign an engineer to actually do the tests and or computations if there were - he'd then have to reject the new part number, propose an alternate or redesign the assembly to handle the new part.
Loring, I did a number of searches, but either got nothing useful or too much to wade through. 'Twould be nice if the searches had a word proximity option, rather than just AND and OR.- David
“Be yourself; everyone else is already taken.” -- Oscar WildeComment
got this one searched for "HF DC Wheel problems"quote:Originally posted by dlminehart
http://www.bt3central.com/forum/topi...Wheel,problems
got this one searched for "HF DC Assembly problems"
http://www.bt3central.com/forum/topi...embly,problems
LCHIEN
