Hot!!!!
  • jeepman71
    • Nov 2008
    • 138
    Hot!!!!
    Hey people, what do you use to cool your shop?.
    My shop is my two car garage and I park my vehicles in it so cooling the garage all day is not an option. I had considered an AC unit but didn't think that would be very efficient trying to catch up after the heat has built up. I had thought about a swamp cooler but was concerned about adding the extra moisture in the air. Over the years I have just not been very active when the heat of summer hits and this really bites.
    Any suggestions?
    I use a portable unit A/C and use it on demand... The operation is simple, Open the garage doors, turn on the overhead air filter, blow the hot air out, close the doors, turn on the A/C, go inside and post to BT3Central for about 30 minutes, go out to the cool shop and work...
    • jeepman71
      • Nov 2008
      • 138
      Thanks for the reply, I will give this a try. Might get too wrapped up in BT#Central and forget to go to work.
        Well, first things first. Insulate to the best of your ability, then add AC, I am doing it backwards and it can be an expensive proposition..
        • sailor55330
          • Jan 2010
          • 494
          I've been thinking about retro-insulating my garage, not because my shop is there (basement--67F year round), but because in the winter the gararge is at 0F.
          I was thinking about cutting about a 4" strip of drywall out near the top and blowing in insulation between each stud, then patching the drywall but I dont' have any experience with this. Something is telling me the pressure build up would make the insulation not settle very well. I do have insulated doors which help a lot. If you don't have an insulated garage door, I remember people getting ridgid foam insulation and cutting panels to fit the inside of the garage door. It helped quite a bit.
          • jeepman71
            • Nov 2008
            • 138
            Thanks dbhost, I have most of the garage insulated. I have one exterior wall that is not but I am dragging my feet on that one because there is a lot of storage space between the studs. The cost to heat it is suprisingly small.
            That is how I insulated the wall that are finished in my garage. It works quite well. A friend's family owned an isulation business and in a nut shell that is how it is done with blown insulation, drill a hole in the wall, blow in the insulation and plug the hole.
            jeepman71
            • gsmittle
              • 2793
              • St. Louis, MO, USA.
              I don't have any cooling in my shop. I just wait for sundown or a cooler day.
              Won't be out there this week!
              g.
              Smit
              "Be excellent to each other."
              Bill & Ted
                g.
                That's about it up here too. Seeing as our winters feel like they last so long, it doesn't often get too hot to work in the shop.
                • Santa Clarita Len
                  • 166
                  • Santa Clarita Calif.
                  • Bt3000 and Dewalt radial arm saw
                  Nothing, .........I enjoy the heat!
                  • Dolsie
                    • 21
                    Drill a hole at the bottom of the wall to deal the pressure build up (advice the home depot guy gave me - take it for what it's worth); I've been planning the same operation. I am planning to replace the top strip with wood though; will give me a solid place to screw/nail to all around the top.
                    • jeepman71
                      • Nov 2008
                      • 138
                      g.
                      That is kind of my problem, I really enjoy summer but like to be able to play in the garage. It's all good, enjoy it while you can.
                      jeepman
                      • jeepman71
                        • Nov 2008
                        • 138
                        I think I have much bigger problems than a hot garage. I just realized I posted this post in Bargain Alerts.
                        Must be time for a fishing pole, cooler full of cold stuff and a shade tree.
                        jeepman71
                        • ironhat
                          • 2553
                          I'm in the 'well insulated and window A/C' camp. I bought the A/C unit a couple of years ago at the end of summer sale at Wal-Mart for about $79. Only run it as-needed except for the past week. It's been in the upper 90's and feeling like 110* and I'm in the middle of a project so I run it 24/7 but on a lower setting at night.
                          Blessings,
                          Chiz
                            Month: 7
                            Lat: 29.785N
                            Long: -95.719W
                            Temperature: 100°F
                            Electric Bill: $331.20
                            Indoor Temperature 75°F: - Priceless
                              jeepman71
                              Moved it for you!
                              I have the magic stick. No thanks required, all part of the BT3Central service.
