Lumber Rack - How Much Weight
    does it have to carry? Or is that like asking how deep a hole is?. I did some searching and found Loring's design.
    http://www.bt3central.com/showthread.php?t=36800
    I will do something similar with 2x4s counterbored and lag screwed to one of the walls. I am surprised he used PVC for the arms. I understand the dowels reinforcing them but didn't think PVC was strong enough for that.
    You'll know how much weight the rack will not hold when it fails. Since you're fastening it to a wall will help. As for Lorings design, I would worry about it being tipsy even with sheet stock on the back side.
    In one of my shops I used 2x4's vertically on the wall, and used 2x4's for the supports. I dadoed them into the sides of the 2x4's (glue and lags). They projected about 16" and could hold some decent weight. I would guess 200-300 pounds each level.
    • headhunter636
      • 161
      • Federal Way, WA
      • Ryobi BT 3000
      I made a rack very similar to the one by Loring but I rested the bottoms of the 2x4 on the cement ledge of my garage and lag bolted the support 2x4 directly into the studs. At one time, I had it filled up pretty high and never had an issue with strength. I like the mobile idea but I am with Cabinetman on the stability of it all.
      Dave
      BT3000
      "98% of all statistics are made up"
        David,
        This thread about shelving loads a "how much wood weighs" may also help, or NOT
        http://www.bt3central.com/showthread.php?t=40907
          • 22106
          i didnt use PVC, I used EMT conduit. The PVC was just a sleeve so the conduit didn't leave stains from the galvanizing (needless worry?) See post 24 in that thread and also Read the details http://www.bt3central.com/showthread.php?t=36523. I think I also estimated the weights.
          I gave a lot of design details and how I arrived at them. Read carefully, follow all the links.
            Thanks Loring. I missed the part about the EMT and was thinking you hammered dowels into PVC conduit. I will look into using the EMT. I might already have some laying around. I might also price out black pipe. That would be plenty strong and I know I already have some laying around. My lumber rack also isn't going to be nearly as big as yours.
              • 22106
              EMT was by far the cheapest metal tubulars i could find, including black pipe.
              • Photojosh
                • Aug 2009
                • 174
                • Washington (the state)
                I gotta tell you, I thought about doing the pipe thing. But for the cost and trouble, I just went with rack system from Grizzly. Same as the ones offered at the other woodworking places, just cheaper:
                http://www.grizzly.com/products/48-W...rs-Pair-/H2534
                Went together in an afternoon.
                  I had some 1 1/4" wood dowel fall into my lap for free so I will use that for the lumber rack. I will drill the holes then put the dowel in then pin it with a screw.
                  • footprintsinconc
                    • 1759
                    • Roseville (Sacramento), CA
                    if you read this thread, you will see what i did. primarily i did what loring did, except that i put it on the wall. i placed the stud at every stud location and drilled multiple holes so that i can have different combinations of shelving available and control the load coming to the wall studs.
                    in fact i did some calcs, with the roof load on, i can load it to approx 500lb each wall stud to max the moment capacity of a douglas fir spruce stud in the strong direction.
                    omar
                    • billwmeyer
                      • 1868
                      • Weir, Ks, USA.
                      I built my lumber rack basically the same way. My 2X4's rest on the floor and used metal conduit. I added angeled 2 X 4 supports under a 3/4" piece of plywood to make a bench for some storage with pegboard above it. So I have lumber stored under and over the bench. I have never had a problem with the strength of it. The Bench is rock solid.
