Yuri... I don't normally get into conversations concerning wiring but.. to someone that does understand wiring you have the capability to run two 110 V lines off the existing un-used in the utility room. To someone that does understand wiring this is a simple task as out-lined by Art.
But.. the key to his commenst lies in the last sentence which is.....
"If you don't understand all the above get an electrician to help".
With all due respect to you.. after reading this thread I am not sure you totally understand and there lies the problem. It would be great to save a few dollars and do it yourself but... it would not be so great to burn your house down because you thought you understood IMO.
I would take a deep breath.. be honest with myself and decide if you Totally understand as anything else as I see is is both dangerous to you and your family. Wiring is something you better get right the first time or there may not be a second chance! You best hire and electrician or have a friend that Totally understands set up the simple procedure that can give you two additional 120 V lines if you wish.
Regards and good luck in your decision....
