corrugated drain pipe for dust collection?
  • billfrommich
    • 74
    Could flexible 6" black plastic corrugated drain pipe (non-perforated) be used in a dust collection system? The corrugations probably increase the frictional losses in the system , and might encourage dust to bulid up (but many long vacuum hoses are corrugated plastic) . On the other hand, it would be easy to make very large radius bends in the system that should reduce losses (compared to the small radius bends encountered when using Metal or PVC elbows). Also there is the question of whether it could stand up to the pressure differential. I'm asking because a Lowes near me is clearing the material out at $6.50 per 10 ft. length.
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    Bill, I think it would cause a static problem in a big way. Not to mention it would hold a lot of dust.
      I think i t might also be prone to collapse under suction, and any kink would weaken it.
        • 22085
        the corrugations are horrible for flow resistance.
        • Jeffrey Schronce
          • 3822
          • York, PA, USA.
          • 22124
          The flex DC hose that you are thinking about has webbing between the ridges to make it much smoother inside.
          As noted it would kill flow in a big way. And don't under estimate the static issue either! Bam!
