More Photos
These two photos show what I meant about no longer using doors under eye level. The four-drawer bench was built in my early woodworking days. At first I liked it very much, but before long began to dread having to try to find anything that wasn’t in the drawers.
The shelves below were full of paints, stains, tools, and many other things. Most of the time you had to get down on your knees with a flashlight to find whatever you were looking for. It wasn’t long before the idea of a replacement bench with all drawers was dreamed up! The old four-drawer became a permanent base for my radial arm saw. The shelves below are used for storage of items that you don’t use every day.
Construction of both benches is identical to the cabinets show above, other than both have a single layer of 3/4 plywood for tops, and the 18-drawer bench top was covered with Formica. (It makes cleaning up paint spills a lot easier.) Single layer tops are fine for tool benches unless you are hammering on them frequently. Then they seem to be a bit “springy.” (Parts tend to bounce around instead of the bench top absorbing the blows.)
To tell the truth, once you have built your first drawer unit or two, all-drawer benches become as easy to build as ones that contain shelves, and they are so much more convenient to use.
