Question for the Jig freaks...
I actually made a simple one on these jigs for my BT when I had it. I took a length of stock ( say around 8" long), cut it in half, reattached the two halves with a strap hinge. Clamped the thing to the SMT fence and set the required distance. After I moved the fence to rip, I could simply swing the block out of the way via the hinge. The neat thing is, you really don't even have to swing it manually. It will move as the stock is fed anyway. Swing it back to readjust the fence for the next rip. Simple and it worked.
ToddComment
I don't think I explained it right. I just clamp it to the fence on the SMT, but don't slide the SMT. The block stays in way in front of the blade, only used as a stop between the stock and the fence, when adjusting the rip fence. Make sense??
ToddComment
Downunder ... 1" = 25.4mmComment
Don is correct. It's in Shop Notes Vol. 16 Issue 94. In place of the block of wood at the end on their version, they used a bearing.
http://www.shopnotes.com/issues/094/"Happiness is your dentist telling you it won't hurt and then having him catch his hand in the drill."
-- Johnny CarsonComment
