Kirby’s Shed: 4. The Back wall
Do you mean that you've only needed to joint boards 10" wide 10 times in 12 years, but use it for narrower stock on a regular basis? Or do you have another jointer/planer? If if you have another jointer/planer, why wouldn't you just use the E-B for everything?Comment
Hey Rod,
I still can't believe that you really work there. Are you sure that its not just a film set.
But in any event, you have a fantastic shop (shed).
Bruce"Western civilization didn't make all men equal,
Samuel Colt did"
10 times all-up - the largest was 6" wide. I don't buy rough-sawn timber. And now I have my Wide drum sander I will probably never use the jointer again
Downunder ... 1" = 25.4mmComment
BTW - My next compressor will have at least twice that tank capacity - I didn't know enough at the time I bought it.
I hear that Rod. I have one of the smaller 2 tank compressors. If and when I get another one....it will be about a 15 gallon + job.Awww forget trying to fix it!!!! Lets just drink beer
Rod, you seem to take the same approach I do: make a little storage rack or box or shelf or whatever and fit it in wherever it'll go, without everything necessarily sharing the same design or detailing. My execution is a bit more, ah, crude that yours, though.
Love the pivoting screwdriver rack. Is that because some of them are hard to reach, over the jointer/planer?
Also, do the rustication joints in the MDF wall panels occur only at seams between the individual sheets, or are some of them just for show?LarryComment
Said it before but here it is again. There is no way Rod actually builds anything in there. He has another shop. I've actually tried and it is impossible to keep a shop that clean.David
The rack lets me store the screwdrivers up close to the hammers, without worrying about space to lift them out
"If you can't hide a joint, feature it!" Only the sheet seams have the 1/4" roundover. (Love the word "rustication" - never seen it before).
Footer Ad
