square peg round hole
  • Crash2510
    • 830
    • North Central Ohio
    ok not really
    my real question is how do you get 4" dust collection hose to go on a piece of 4" sch 20 pipe
    Please help
    Phil In Ohio
    The basement woodworker
  • Tamarack
    • Oct 2003
    • 199
    • Speedwell, TN USA
    Duct Tape? "Don't leave home without it!"
    Paul in Idaho
    (5 more months to retirement)
    • Tom Miller
      • 2507
      • Twin Cities, MN
      I can get the 4" wire-reinforced clear hose (from WoodCraft/Rockler) over the end of sewer&drain pvc (sched. 35), by removing a few turns of the reinforcing wire. It's a snug fit, but I usually use a hose clamp to keep it in place. A 6" long piece of PVC stuck half-way into the hose makes for a quick-connect fitting.
      Regards,
        That's where I put my blast gates. Makes a nice transition.
        • jdoolitt
          • Jun 2004
          • 124
          Ditto JR - blast gates. I just completed my DC setup. Used S&D everywhere except to connect up to the shop tools and the dc itself. Blast gates fit perfectly inside the 4" S&D and the 4" flex lines I am using.
          • just4funsies
            • 843
            • Florida.
            Most of the companies into dust collection sell an adapter fitting that makes the transition clean and neat. No need to jury-rig (unless you enjoy the challenge).
              • 22108
              when you guys talk about 4" S&D, the 4" S&D I see at the local box stores is 10' long and flared at one end (to accept another section w/o a fitting). Is that the stuff?
              • Tom Miller
                • 2507
                • Twin Cities, MN
                Yep, that's the stuff!
                Fittings are also thinner than the usual schedule 40 stuff -- sometimes made of polystyrene.
                Regards,
                • meika123
                  • 887
                  • Advance, NC, USA.
                  Originally posted by Crash2510
                  ok not really
                  Please help
                  I have been taking a piece of piping and sawing a small slice-lengthwise out of it, fitting it into the two pipes and taping it with-"TA DA " duct tape. Works for me.
                  Dave in NC
                  • jbalders
                    • Oct 2003
                    • 298
                    • Vienna, VA, USA.
                    • BT3100 + Shopsmith
                    ok not really
                    Please help
                    You use the correct adapter, that's how.
                    http://www.woodcraft.com/family.aspx?FamilyID=5815
                    They may be available elsewhere, but I haven't been able to find them.
                    Jeff
