Pretty cool design. I could use something like that, but I don't have any wall space left.
Space Saving Clamp Rack Design
Pretty cool design. I could use something like that, but I don't have any wall space left.Comment
Good basic design, I looked at it pretty carefully and would suggest the following changes.
1. Use Continous (Piano) hinges, rather than a bunch of short ones.
2. Consider using Window hardware latches to keep the sections closed, much more secure than a magnetic latch.
3. install guide pins in the edge of the cabinet to transfer the weight back to the base unit when it's all closed up. These could be 3/8" dowel rod that stick out about 3/8" and mates with a 3/8" Chamfered hole in the Frame behind it. You'd only need one in each sub-frame to steady/secure the unhinged side of the frame to keep it from moving vertically.
4. Consider using 3/4" Baltic Birch for the slotted horizontal members. This might eliminate the need for the braces between each pair of slots.Last edited by gmack5; 03-03-2006, 11:48 AM.Stop thinking why you can't and Start thinking how you CAN!
GeorgeComment
Thanks for posting! The rack looks great. Design is simple and should not be that hard for a newbie like me to copy.Chris
"The first key to wisdom is constant and frequent questioning, for by doubting we are led to question and by questioning we arrive at the truth." -Pierre Abelard 11th Century philosopher.Comment
