Space Saving Clamp Rack Design
  • gad5264
    • 1407
    • Columbus, Ohio, USA
    • BT3000/BT3100NIB
    I found this site on the internet last night. Looks like a decent design for a clamp rack.
    http://woodworking.phruksawan.com/clampCabinet/
    Grant
    "GO Buckeyes"
  • BobSch
    • 4385
    Interesting design, but I'm not sure it's very scalable. If you made it much bigger I'm not sure I'd want to trust the double set of hinges with much weight.
    Bob
      That IS pretty cool. Bookmarked for future reference.
      Bob: excellent point, but you could "scale" the rack up by making two (or three, or four, or ...) of them.
        • 22098
        Really Nice idea.
        • Jeffrey Schronce
          • 3822
          • York, PA, USA.
          • 22124
          That is absolutely awesome. I am definately going to build this next week.
          • greencat
            • 273
            • Grand Haven Mi
            • 3100
            I think this will be my first pocket screw project.
            Do you think pine would be strong enough not to sag?
            Thanks again,
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              Great idea. Thanks for posting it.
              Monte (another darksider)
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                I read it a little closer after your mention of using pocket hole joinery. He states he used bisuits in the construction. Anyone know exactly where? I see a couple of long wood screws in each butt joint.
                If you are just dying to do your first pocket screw project it would work, however I think just butt joining with 2 1/2" cabinet wood screws would be much, much quicker.
                I am going to use poplar. I think pine would be fine, especially since each of the fingers have supporting blocks.
                • greencat
                  • 273
                  • Grand Haven Mi
                  • 3100
                  Since this is a shop grade project I wonder if he used bisuits then screws instead of clamping.
                  I know the pocket screws are over kill but I just got it and thought I would give it a try. If I was doing it for speed, I would glue the butt joint then drive a few nails then put in some screws. Are cabinet screws better than dry wall? Is it becasue of the the non-threaded area?
                  The more I think about it I may skip the pocket screws since I don't have that 90 degree clamp. Has anyone taken a HF clamp and made a 90 degree clamp?
                  Thanks again,
                  • Jeffrey Schronce
                    • 3822
                    • York, PA, USA.
                    • 22124
                    Ya, I understand. Got a new tool, got to use it! Pocket hole should work fine. Hint on Pocket Hole Joinery, for me personally the clamp is very, very important.
                    Yes, I like cabinet screws much better than drywall screws. I especially like "star" heads instead of stupid Phillips head.
                    • WEG
                      • 298
                      • Nahant, MA.
                      Hi Grant;
                      Nice idea, thank you for posting it. I was thinking like Larry when the question came up about "scaling" it to a larger size. I think I will make two side by side swinging opposite each other like a two door medicine cabinet opens. Should be pretty neat. As for the fastening, I'll put a rabbet on the verts and place the horizontals on those I think, then a little glue and nails to hold it all together...Woo Hoo, the weekend is all taken care of! Now just find some wall space..hmmm....
                      WEG
                      • Brian G
                        • Jun 2003
                        • 993
                        • Bloomington, Minnesota.
                        • G0899
                        The author knows a good tablesaw, too.
                        Actually, my memory thinks it remembers seeing his name in a signature here.
                        I like the idea. I'd probably focus on putting the heavy clamps in the back, and the lighter bar clamps in the front.
                        Brian
                        • jarhead
                          • 695
                          • Boynton Beach, FL.
                          Brian,
                          You're correct - I think he posted a picture of a splitter he had made for his BT3100.
                          • Tundra_Man
                            • 1589
                            • Sioux Falls, SD, USA.
                            Pretty cool design. I could use something like that, but I don't have any wall space left.
                            Terry
                            • Tundra_Man
                              • 1589
                              Terry
