Outside Diamater of 1/2" black Iron Pipe
  • pierhogunn
    • 1567
    • Harrisburg, NC, USA.
    What is the OD of 1/2" ID black Iron Pipe?
    Dan
    Monty Python's Flying Circus
    Dan in Harrisburg, NC
  • Thom2
    • 1786
    • Stevens, PA, USA.
    • Craftsman 22124
    • pierhogunn
      • 1567
      what is that in fractional?
      Dan
      • Jim Boyd
        • 1766
        • Montgomery, Texas, USA.
        • Delta Unisaw
        Dan
        About 1/32" less that 7/8".
        • RodKirby
          • 3136
          • Mao Shan TSC-10RAS
          How about 21.3mm
          Downunder ... 1" = 25.4mm
            • 22012
            840/1000"
            84/100ths
            21/25ths.
            are there other fractions?
            • pierhogunn
              • 1567
              okay, so I am figuring a 13/16ths drill bil will be just under the .840, which would allow me to sand/file out the hole for a real tight fit around some 1/2"ID black iron pipe (this is for the copy stand)
              dan
                • 22012
                dan
                Ah the real season comes out.
                If you want a fit that you can move and then lock in place,
                cut a little oversize hole in a piece of 3/4" thick wood block. Makes a square "Ring" - leave about 1/2" on each side.
                Then use a bandsaw or table saw to cut the ring across the hole.
                Use a long wood screw to connect one side back together and
                then use a semi-captive bolt and a threaded knob to tighten the other half.
                The kerf of the cut will close up the hole around your pipe, and the knob will allow you to mkae it tight to hold or loose to slide.
                You'll need to do some deep and neat countersunk holes and stuff.
                • pierhogunn
                  • 1567
                  actually, there will be a 3/8" dia screw that is running down the length of the pipes to provide the heigth adjustment for the copy-stand arm, I just need to make sure that the holes in the arm-carriage that the 2 pieces of pipe pass through have tolerances as close to .840 as possible so that there is very little play.
                  The plan is to make a 13/16 hole using a forstner bit, and then take off about 1/16" to make the fit real nice and tight.
                  This way, when the weight of the camera is exerting downward force on the arm, the carriage and the arm will reamine nearly in plane with the base of the stand. To make the top and bottom of the carriage I will clamp all 4 pieces together and bore them at the same time, so al l holes line up perfectly
                  Dan
