What finish for an ironing board made of pine?
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    I made an ironing board from cheap pine. When in use it will be wrapped in the standard foam+cotton cover.
    What sort of a finish is best for this? Acrylic (or latex) paint? Or tung-oil/Shellac finish? Or just lacquer?
    While the hot iron will not touch it directly, I believe quite a bit of heat will be transmitted...
    I am okay re-finishing it at some interval, don't expect any finish to last forever.
    - Aristotle
    • 3784
    Tinfoil?
      dbhost
      commented
      Nah, that is for hats.
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    I finished the one I made for my wife with an oil based polyurethane. IIRC, I put on three coats. That was years ago and we haven't had to anything to it since then.
    • radhak
      • 3061
      • Miramar, FL
      Good to know that - did you have to seal the wood first? Or just the poly on bare wood?
      - Aristotle
        • 8795
        My idea was polyurethane also. Shellac and most lacquers generally won't stand heat as much as poly can, in my experience.
        • sweensdv
          • 2873
          • WI
          I just sanded it to 180 grit then applied the poly.
