DIY camera jib / crane
    Been doing a LOT of video work lately, and I have been wanting a Jib crane, but buying one, even a cheap one from Amazon, is a considerable expense... So I turned to the DIY route. I am not quite finished yet, but the initial build results look promising for my future videos...
    Construction is cabinet grade ply of various thcknesses, aluminum pool poles, PVC and steel. It's a bit fugly, but all the important moving stuff moves the way it is supposed to. I am thinking this will get a coat of matte black spray paint, at least the brackets will before I start using it so that it does not impact the light getting to the camera...
    Once I figure out the counterweight to it, I will do a sample video and snap some pics to share with y'all as well as do a full build write up.
    • 22108
    Care to give a commercial example of what you are trying to do?
    I recently built a macro stand for working with closeups and light tents. - required a bunch of counterweights. and a cantilevered, articulated camera mount.
    Most macrophoto stands are for taking flat items from straight above.
    I have yet to test it out though.
      I am building my own implementation of this guys build... Mine differs in that I used a plywood base with a brass thread insert to mount to the tripod.
      https://youtu.be/QkW1etZb2eo
      It's considerably heavier than I anticipated, but I am sure it will do what I want it to do...
