I thought I could route some small 1/2" thick plywood pieces. I wanted plywood because I thought I wanted some wood that wouldn't split along the grain.
I tried to use a 1/2" pattern bit like this from MLCSWoodworking
in a router table. THe pieces were about 5" long which is a bit of a problem because the pivot pin was about 3" from the bit.
When I tried to start the wood feeding it the correct direction into the spinning bit, it grabbed and it was like routing end grain the whole way around. I didn't go very far as I really didn't feel comfortable. Felt like it was chattering a lot. Made a mess out of the wood. (see picture below).
Is is practical to pattern rout plywood?
I'm going to make a holder jig with some 3/4" wood and a jig (toggle) clamp holding it from above. I'll have to raise the bit 3/4" more to compensate.
Is this the best way to do this? I'm Not too happy with the way this has gone. I'm going to have to go back and cut another blank...
In the picture below I have a 1/4" plywood pattern. I cut close with a bandsaw and pegged the two pieces together with a 1/4" bit and a dowel and a 1/4" transfer punch I thought might help make a safer handle than holding the piece.
THe last picture shows the completed routed piece after I slowed the router some (probably backed from 20,000 to 16,000 RPM) but it looks like heck.
I have several more I want to do.
LCHIEN
