Stupid walls are only 2x4 stud construction... That limits me to R13 in fiberglass... Oh well...
Starting the process with the electrician, phase 1.
Please like and subscribe to my YouTube channel. Please check out and subscribe to my Workshop Blog. -
You could fill the cavity with R13 and go on top of it with rigid under your sheetrock or plywood sheathing. 1" of the rigid foam will give you about another R5, which is also continuous and performs a little bit better than just cavity insulation. Wood isn't very conductive, but it does conduct some heat. Probably not in the budget though.
Setting the elec boxes can get a little tricky too.Last edited by pelligrini; 07-05-2012, 04:35 PM.ErikComment
In a 2x4 wall cavity, which my brother's house was, youc an still fill with 3" of closed cell foam. At R7 per inch, that's an R21. Also, you have the benefits of it improving structure, dampening noise, and sealing all air leaks (which will give an R21 in foam a better insulative value that R20 in fiberglass).
Though, it's definitely more $$.Comment
