I have an electrician, that is a business partner with a fellow I work with, that several of my colleagues have worked with and been very happy with.
We are working it for $65.00 / hr for him, and a helper to pull the permits, replace the main panel (damaged by Ike, and workable for the sub panel project, but will not allow for any further upgrading afterwards), and run the new sub panel, and circuits. He will provide a materials list, and its up to me to get the parts / materials.
LOML insists on getting the bigger main panel, and flat out says that "just in case you want to move your shop out to a shed down the road"... every time I hear that phrase, I cringe a little bit... But hey, a dedicated shed / shop would be just that, completely dedicated. No lawn mower, no weed eater, no none of that junk. And specifically, no flower pots, no potting soil and no miracle grow to get spilled on my jointer, again!
I talked with the guy across the street and got measurements on his shed, 16x20 with a 14 foot roof peak height. If I can get them to green light that size, I would only loose 2 feet, but be completely dedicated to wood shop. A good trade off if you ask me!
For now, the projects are moving ahead, SCMS / Mortiser bench is scheduled to begin construction this weekend. For now, I will build it to be a big, open faced box. Existing storage media, the clamshell cabs, and totes, will get shoved in there. The DC ducting will have to come down in large segments and stowed aside for safe keeping. And then the wrecking crew can get to work (my wife, my brother in law, and myself with hammers, masks and gloves) tearing out the walls on the east and south sides... Then make the call... Yoo Hoo the walls are down to bare studs! Come run my power!
I hate doing sheet rock work, but this is something I am looking forward to big time. Get the insulation in place, and re rock these walls... Seal up the gaps, and flip the switch on that AC or heater!
Now I know some are going to ask why I didn't wait until I got the power done to get my bigger compressor. The answer is simple, while I will be pulling 220v service in to the shop for future growth, I specifically wanted a 110V compressor for portable work. YES this compressor is hardly an ultra portable, but when I need to haul it to a friends place to help them with framing or what not, it will be great to be able to plug it in and get to work!
I am curious about installing the kraft faced fiberglass batts though. When working from inside, which way does the paper go? I assume it goes to the inside, but I have heard elsewhere that it is supposed to face OUT in hot climates. Which is right?
