Tape residue
  • jeepman71
    • Nov 2008
    • 138
    Tape residue
    Good Morning,
    What do you use to remove tape residue from your projects?
    VM&P Naptha works pretty good.
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      Mineral Spirits
        What cabinetman said and sometimes I'll just use a cardscraper.
        • woodturner
          • Jun 2008
          • 2049
          • Western Pennsylvania
          What kind of tape? For masking tape residue, alcohol such as rubbing alcohol will dissolve the adhesive residue and is less likely to harm the finish than some of the other products mentioned.
            • 22072
            my general rule is try stuff in order of aggressiveness,
            usually try rubbing your finger first, some stuff just rolls off with pressure.
            Then try rubbing alcohol.
            Then try stuff called Goo Gone - that generally removes most label glues.
            After that you need to go to nasty stuff, like lighter fluid, mineral spirits, turpentine, acetone etc that generally I don't like to use and or even keep around for flammable and vapor reasons.
            • Charlie R
              • Jun 2007
              • 90
              WD-40 removes price tag labels and most other adhesives.
              • jeepman71
                • Nov 2008
                • 138
                Thanks for the replys everyone.
                I use all of the above but was checking to see if maybe there was another silver bullet. I have not had any negative affect on finish from any of these items but don't want to find out the hard way.
                By the way the tape I am generally trying to clean up is double sided or carpet tape.
                • Bruce Cohen
                  • 2698
                  • Nanuet, NY, USA.
                  The world's best kept secret, RUBBER CEMENT THINNER.
                  You can probably get it at an art supply store (if they still exist), or try a craft's store like AC Moore.
                  Although is is flammable, it doesn't smell as bad as all the other stuff and won't mess your hands or the work.
                  Bruce
                  Samuel Colt did"
                  • jaybee
                    • 157
                    • Regina, SK, Canada
                    If you have any "leftover" freon tp-35 - it works well.
                    See this thread
                    http://www.bt3central.com/showthread.php?t=33342
                    I also deny having any
                    • RAV2
                      • Aug 2007
                      • 233
                      • Massachusetts
                      • 21829
                      I have had great success using the same tape and 'dabbing' it over the left over adhesive. It seems to pull the unwanted residue off the item.
                      • gerti
                        • 2233
                        • Minnetonka, MN, USA.
                        • BT3100 "Frankensaw"
                        You beat me to that suggestion. For sticker residue etc. I sometimes use scotch tape, often works ok.
                        • jeepman71
                          • Nov 2008
                          • 138
                          kInd of like using majic marker to remove majic marker, works quite well. Of course it only works on solid surfaces like metal. I'll have to give this a try some time.
